Gas Powered Genrators - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 04:33 PM   #1
Lightbulb
i have a 1500 sq. ft. home and I want to power approximately 50% of it in a power outage. I am looking into a gas powered generator and want to know if a 6000W one will work? Load? AMPs? etc......I am not able to calculate this and just need a possible idea.
mochiebi is offline   Reply With Quote
Old 01-04-2012, 04:55 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... It'll run Most of what's found in Most homes....
It Won't power electric heat,...
It won't power an electric water heater, unless it's the only thing it's powerin'...
In other words, it Depends on the Loads expected...
Old 01-04-2012, 04:58 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Just knowing that home is 1500 sq/ft is not remotely enough to help you.
We need more info.
Old 01-04-2012, 05:04 PM   #4
MarginallyQualified
Rewards Points: 2,464
each gizmo you want/need to provide power for will have a "rating plate" on it with the watt and volt information. There are also a load of online resources to use as well.
make a list of your gizmo's and their wattage needs... add that up.
6000watts / 120volts = 50amps - 20% safety = 40 amps
and everything doesn't run 100% of the time
hth
Need a new powered Hose Reel--Need Advice. kennykenny Gardening Forum 0 06-07-2011 12:10 PM
Thinking of adding powered roof vents. budster Roofing/Siding 12 05-02-2010 02:27 PM
Where could I get something like this powered baffle. Hossenfeffer HVAC 6 04-05-2010 11:40 AM
Non-Gas powered mowers. Experience? Thoughts? IckesTheSane Landscaping & Lawn Care 3 12-03-2008 02:04 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
