06-18-2012, 02:39 PM
#1
gas oven has 3 prong plug, outlet is 4 prong
where can I buy an adapter for my new oven
06-18-2012, 02:42 PM
#2
Electrical Contractor
Someone posted an adapter that was good for use in canada. But in the US you have to use a kitchen circuit or run a new circuit.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
#3
Semi-Pro Electro-Geek
Is this JUST a gas oven, or does it have an electric cooktop? Does it have a normal 120V plug, or is it a big 240V 3-prong plug? I assume the receptacle is for an electric range?
06-18-2012, 05:46 PM
#4
E2 Electrician
You can't buy an adapter, you have to replace the cord on your appliance to a 4 wire cord with matching amperage of the receptacle, and separate the neutral/ground connection at the over when you do this.
06-18-2012, 05:48 PM
#5
Licensed Electrician
Gas oven = 120V
4 prong plug = 240V
No adapter, you will need to do some rewiring.
Location...Location...Location
06-18-2012, 05:53 PM
#6
A "Handy Husband"
If the poster is in Canada he can use this:
http://www.homedepot.ca/product/gas-...adaptor/905477
If in the US, you need to rewire.
Another reason for poster to include their location in the profile
Coastal South Carolina
#7
E2 Electrician
Originally Posted by k_buz
Gas oven = 120V
4 prong plug = 240V
I missed the "gas" part, but this could be a duel fuel?
EDIT.... Ahhh, I love other countries...
06-20-2012, 02:32 PM
#8
Just curious why that adapter only works in Canada?
According to this they use the same voltage and outlets as the US:
http://www.adaptelec.com/index.php?m...roducts_id=282
Just wondering because I have an electric range and one day wouldn't mind converting it to gas if it ever goes bad.
06-20-2012, 02:55 PM
#9
It would work fine in the US, but they don't sell them here because they're not UL listed. As I recall, the adapter has a fuse in it so the 120V receptacle is properly protected. I'm not sure why they can't be UL listed - it seems perfectly safe to me.
06-21-2012, 05:43 AM
#10
It probably would work !
But not code compliant.
CODE IS GOD
All bow now !
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
