Gas In Oil Tank - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 08:57 AM   #1
gas in oil tank
i haven't used my generator i a few years went to start it and found i have gas in the oil. are there repair manuals out there and parts?? if so how do i get my hands on them??
slshaver11 is offline   Reply With Quote
Old 02-12-2013, 09:04 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will have to clean the carburetor and change the oil. Probably a stuck open needle valve in the carburetor flooded the engine and got into the oil. I would clean the carburetor change the oil and install a fuel shutoff so when you are done using it you turn off the fuel to the unit and let it run out of fuel. If it's electric start make sure you turn off the key when it stops running.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 09:07 AM   #3
Rewards Points: 13,732
I'd guess you left the fuel valve on and the needle valve in the carberator is stuck and it dumped fuel into the top of the cylinders which leaked past the rings into the crank case.
Drain the oil, rebuild the carberator and you should be back in business.
A simple way to cheak to see if that's the case is to shut off the fuel valve, remove the bowl on the carberator and turn the fuel back on. As it's dripping lift up on the float, it should completly shut off the fuel flow.
Old 02-12-2013, 09:34 AM   #4
Rewards Points: 1,514
If dismantling the carburetor (let alone rebuilding it) intimidates you, you could install the cutoff valve in the fuel line from the gas tank and use that as described above and, if the generator still runs, not bother to touch the carburetor.
AllanJ is online now   Reply With Quote
Old 02-12-2013, 10:48 AM   #5
Rewards Points: 3,130
What brand of generator is it? Who is the manufacturer of the engine? If it's somebody common like Briggs & Stratton, Onan, Generac, etc., there's most likely a manual and parts available for it. If it's a cheap Chinese unit, you're likely out of luck. But that said, the carburetor probably doesn't need to be rebuilt, just taken apart and cleaned. There's not a lot to those little ones so it isn't hard to do. They actually have only a few moving parts.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 06:43 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
