Gas Line Near Branch Load Center - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 05:02 PM   #1
Gas line near branch load center
Installing a branch load center for a unfinished room above garage, main load center is in garage so I naturally want the branch to be close as possible. There is a propane gas line coming up from garage and up along the stud where I was going to put a gas log setup, but Im not going to do this anymore so the line will stay behind the wall and the shutoff valve will be installed. I just wanted to know what the NEC says about having a load center near a gas line.... any help would be very helpful.
pyroarchy is offline   Reply With Quote
Old 03-02-2012, 05:33 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
The Code doesn't mention anything about electrical equipment being near gas lines, but the requirement for dedicated space for the equipment does come into play. Check this picture, see if it helps.
Kyle
Old 03-02-2012, 06:00 PM   #3
Rewards Points: 6,652
I would try and re-route it if you can.
Old 03-02-2012, 06:57 PM   #4
Thanks guys, yea I wanted to remove the gas line but my dad said he doesn't think mapp gas can braze it with the length of the copper, and he borrowed a larger acetylene to do the job originally. We are going with a ductless heat pump so its useless to use and most future homeowners.
Old 03-02-2012, 07:05 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What is the gas pipe made of?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-03-2012, 02:32 AM   #6
Prob. Copper, and very thin wall at that most likely, if it came off of a spool.
Old 03-03-2012, 06:41 AM   #7
Code05's Avatar
Rewards Points: 1,104
Agreed. I would a flaring tool and move it.
http://www.sears.com/shc/s/t_10153_1...ring-tool.html
Code05 is offline   Reply With Quote
Load Center Generater Interlock in Cook County, IL shilohqdog Electrical 2 02-20-2011 03:57 PM
GE Load Center nomenclature kb01 Electrical 3 10-28-2010 01:15 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
