Gas Fire Place Install - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 05:43 PM   #1
gas fire place install
I am having a gas fireplace installed with a blower. I do not have any space left in my panel for another breaker. Can I put in a junction box currently servicing 4 outlets and 3 60 watt celling lights (I only use about two outlets.) it is currently a 15amp breaker. if I did a junction box, I would tap in before the first oulet.
thanks
couchguy is offline   Reply With Quote
Old 12-16-2008, 06:45 PM   #2
thanks
A 15 amp breaker will provide more than 1800 watts, so as long as this is not exceeded, you will be fine!
Old 12-16-2008, 07:34 PM   #3
Registered User
Termite's Avatar
Or use a tandem/twin breaker that is essentially two breakers in one slot.
Old 12-16-2008, 07:59 PM   #4
How many watts is the fireplace?
I'm sure it would be a low amount, but best to ask anyway...
Billy_Bob is offline   Reply With Quote
Old 12-17-2008, 11:12 PM   #5
New House Newbie
Rewards Points: 95
I was just figuring out my gas fireplace install yesterday and they guy at the fireplace store says a blower only runs about 3 amps....so tapping off your outlets will work.
C_J_GO is offline   Reply With Quote
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Fire place rookie_1 HVAC 4 11-18-2008 11:24 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
