Old 03-12-2012, 07:52 PM   #1
Limited Experience
Gas dryer electrical outlet
Can a gas dryer share the outlet with a washer in a utility room?
What if they are small under counter units in the kitchen?
raleighthings is offline   Reply With Quote
Old 03-12-2012, 08:02 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
The washer should be plugged into a dedicated laundry circuit. The gas dryer can share this circuit & receptacle.
The Following User Says Thank You to Speedy Petey For This Useful Post:
plummen (03-13-2012)
open neutral on dryer...dryer won't work inspectorman Electrical 32 02-20-2012 03:16 AM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 05:38 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 08:00 PM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
