Garbage Disposal Wiring - Hardwire Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 06:27 AM   #16
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by gregzoll View Post
electures, not every AHJ requires the same restriction. Some actually tighten the restrictions, and the NEC, more than others. That is why it is stated over and over to check with your locals, not rely on web info or the NEC for everything.
Hence, the reason for the last sentence in my post.
"Again, this all depends on local and state codes and the EI."
electures is offline   Reply With Quote
Old 06-18-2011, 07:23 PM   #17
Rewards Points: 1,578
Only a bubba would put a GFCI behind a DW. Anyone in their right mind would put it in the sink base to be accessible.
Just for fun: So, a line needs to be run from DW to the GFCI outlet in the sink base. Even if they were side by side, you'd need to run NM, MC or something to the sink base and then convert to appropriate plug for the GFCI. More problems caused than solved IMO.
bob22 is offline   Reply With Quote
Old 06-18-2011, 10:44 PM   #18
Rewards Points: 6,652
It depends on the AHJ. If I wired a dw or dispos-all, it would be GFCI breaker or outlet, with BX or armored as it should from the JB to the outlet, to the switch.
As for the GFCI, it should either be a breaker or if a outlet, installed in the sink base in a way that a person can access it without tearing stuff apart.
Old 06-19-2011, 09:38 AM   #19
electures's Avatar
Kitchen appliances are not required to be GFI protected. Follow the link in my signature and verify what code your state has adopted. Otherwise, safe your money.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
220 Volt Electrical Wiring Question ... for light ??? shotguns Electrical 11 05-21-2011 09:03 PM
Replacing disposal...wiring regs twinrider1 Electrical 2 04-28-2011 05:19 PM
kitchen faucet with spray nozzle, dishwasher and garbage disposal iklektic Plumbing 2 03-24-2011 10:53 PM
Disposal wiring Shammie Electrical 6 03-08-2011 11:21 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
