Garbage Disposal Wiring - Hardwire Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 03:22 PM   #1
Rewards Points: 262
garbage disposal wiring - hardwire question
Planning for a hardwired garbage disposal in a kitchen renovation. Does the 12/2 NM cable just come in through a hole in the back of the cabinet to get connected at the garbage disposal's built in wire connection cavity? Is there a nice way to bring the cable through the wall that looks a bit more "finished" than just feeding it through a hole in the gyp. bd.? Thanks.
tpagel is offline   Reply With Quote
Old 06-17-2011, 03:31 PM   #2
Missouri Bound's Avatar
If the disposal is designed to be hardwired, then there are several "whips" which could be used to neaten up the installation. The existing circuit would need to be terminated in a junction box at the wall, then a whip could finish the connection from the box to the disposal with proper wire size, connections and junction box.
Old 06-17-2011, 04:00 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I just run the romex directly into the unit. Just keep it up and away from anything in the cabinet. Use a romex connector.
electures is offline   Reply With Quote
Old 06-17-2011, 04:25 PM   #4
Rewards Points: 6,652
Only problem is, that is not the correct way, and not all jurisdictions allow direct wiring of Romex to the disposal.
Old 06-17-2011, 04:36 PM   #5
Rewards Points: 262
I would very much prefer to have a cord and receptacle situation. Do insinkerators (for instance) give an option for either, or are most hardwired?
Old 06-17-2011, 04:45 PM   #6
You have to put in a GFCI outlet underneath, a switch to control the outlet, and yes a cord attached and secured to the Dispo-all. Keep in mind rules vary local to local, so check with your AHJ.
Old 06-17-2011, 04:49 PM   #7
Rewards Points: 262
I actually planned for the switch and receptacle, and have it wired that way now. Today I sat back and wondered if the GD had that option, and as I researched installing these things on Youtube, they all seemed to be hardwired, so I thought maybe I made a mistake.
Old 06-17-2011, 05:06 PM   #8
Too Short? Cut it Again!
I prefer them plugged into an outlet. It makes it easier to switch a fried one as some lines use a common mounting bracket and you can just twist a new one in place and plug it in. I think most have the option of doing it either way subject to preference and local code. You have to buy the "pigtail" with the plug on one end and the wire connections on the other.
Old 06-17-2011, 05:55 PM   #9
electures's Avatar
Yet again we need more information. According to the 2008 NEC;
422.16 Flexible Cords.
(A) General.
Flexible cord shall be permitted
(1) for the connection of appliances to facilitate their frequent interchange or to prevent the transmission of noise or vibration or
(2) to facilitate the removal or disconnection of appliances that are fastened in place, where the fastening means and mechanical
connections are specifically designed to permit ready removal for maintenance or repair and the appliance is intended
or identified for flexible cord connection.
A flexible cord shall be permitted. It can be hard wired. The switch at the sink can serve as the required disconnect.
If it is cord a plud connected (which is convenient) the receptacle under the sink is not required to be GFI protected.
210.8 Ground-Fault Circuit-Interrupter Protection for Personnel.
(A) Dwelling Units.
All 125-volt, single-phase, 15- and 20-ampere receptacles installed in the locations specified in
(1) through (8) shall have ground-fault circuit-interrupter protection for personnel.
(6) Kitchens — where the receptacles are installed to serve the countertop surfaces
Receptacles for disposals and D/W's do require GFI protection. Again, this all depends on local and state codes and the EI.
Old 06-17-2011, 06:02 PM   #10
Rewards Points: 262
Thanks for all the replies and insight. I will check with my building inspector to see if he has any preference or requirements.
Old 06-17-2011, 06:56 PM   #11
Rewards Points: 1,766
So if a GFCI outlet is installed in the wall behind the DW and the DW is plugged into the outlet what does the homeowner need to do to reset the GFCI if there is a nuisance trip?
bob22 is offline   Reply With Quote
Old 06-17-2011, 08:22 PM   #12
electures, not every AHJ requires the same restriction. Some actually tighten the restrictions, and the NEC, more than others. That is why it is stated over and over to check with your locals, not rely on web info or the NEC for everything.
Old 06-17-2011, 08:23 PM   #13
Only a bubba would put a GFCI behind a DW. Anyone in their right mind would put it in the sink base to be accessible.
Old 06-17-2011, 08:34 PM   #14
Yep. The GFCI is not required UNDER the sink. The rule if for outlets which supply the countertop.
The Following User Says Thank You to Missouri Bound For This Useful Post:
electures (06-18-2011)
Old 06-18-2011, 06:26 AM   #15
electures's Avatar
The receptacle is not required to be GFI protected. Only counter top receptacles.
"Again, this all depends on local and state codes and the EI."
220 Volt Electrical Wiring Question ... for light ??? shotguns Electrical 11 05-21-2011 09:03 PM
Replacing disposal...wiring regs twinrider1 Electrical 2 04-28-2011 05:19 PM
kitchen faucet with spray nozzle, dishwasher and garbage disposal iklektic Plumbing 2 03-24-2011 10:53 PM
Disposal wiring Shammie Electrical 6 03-08-2011 11:21 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
