Garbage Disposal And Dishwasher Sharing Circuit - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 09:42 PM   #31
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Originally Posted by k_buz View Post
This, however, I don't think is the reason. What is going to limit them from being used at the same time? They are used simultaneously all the time in my house.
Mine too. A 3/4hp newer ISE disp and a Kitchenaid DW. Both on the same 20A circuit, NEVER tripped a breaker. And we use both a LOT.
Old 07-08-2012, 09:45 PM   #32
(2) Utilization Equipment Fastened in Place. The total
rating of utilization equipment fastened in place, other than
luminaires, shall not exceed 50 percent of the branchcircuit
ampere rating where lighting units, cord-and-plugconnected
utilization equipment not fastened in place, or
both, are also supplied.
I guess if you read it really closely, this rule doesn't address a circuit supplying only utilization equipment fastened in place.
I forgot about this, and I agree.
IMO there is NO 50% limit if the only thing on the circuit is fastened in place. You can have ten appliances on the same circuit, all fastened in place, if you want.
Old 07-08-2012, 09:46 PM   #33
I'm still waiting on kontoose to tell me what code I should follow.
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (07-09-2012)
Old 07-08-2012, 10:44 PM   #34
...Why, the non-anal retentive code, of course...
kontoose is offline   Reply With Quote
Old 07-08-2012, 10:47 PM   #35
Oh, I get it. You mean the one you make up because you don't know the real one.
No problem.
Old 07-09-2012, 12:27 AM   #36
Read the code book...and leave your nails...alone.
Old 07-09-2012, 07:29 AM   #37
I'll try that.
OK, so I did, and I found this:
both, are
also supplied.
Did you find anything to support this:
Just follow the code. Garbage disposals and dishwashers (each) shall be on a dedicated 20amp circuit.
Let me ask you this. How is this any different than having two large power tools, plugged into two garage receptacles, on the same circuit?
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
amakarevic (07-09-2012), frenchelectrican (07-09-2012), gregzoll (07-09-2012), jbfan (07-09-2012)
Old 07-11-2012, 01:12 AM   #38
Yes, this code stipulation usually refers to the kitchen and breakfast room areas. (I.e, you can serve the adjacent breakfast room outlets, and/or lighting with any of the kitchen circuits...as long as less than, or equal to, only 50% of the over-current protection device is taken up by a "permanently installed" appliance, or unit of equipment.
It's a "cheesy code", but Limburger lovers...tend to change their socks more often than Cheddar nibblers.
I take it you're Swiss...considering the holes in your code knowledge...?
Old 07-11-2012, 06:06 AM   #39
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You'll have to actually give a code section if you want anyone to take you seriously...
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (07-11-2012), Jim Port (07-11-2012), Speedy Petey (07-11-2012)
Old 07-11-2012, 06:29 AM   #40
Yeah, OK.
It's stupid comments like this, and not posting anything factual, that will prevent anyone from thinking you know what your talking about.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
electures (07-13-2012), Jim Port (07-11-2012)
Old 07-13-2012, 12:26 AM   #41
Circle jerk
I heaqr you...
Old 08-29-2012, 12:48 AM   #42
Rewards Points: 1,062
so does the NEC code stipulate a mandatory amperage for a garbage disposal anywhere? like for example 20, which would sound like a hell of an overkill but i wouldn't be surprised if it did. i cannot imaging that a GD would draw more than 3-5A max ever considering that a circular saw even seldom reached 10 (e.g. if you are cutting really hard materials)
in other words, can i have a GD on a dedicated 15A circuit?
thanks
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 04:43 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 11:13 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
