Garbage Disposal And Dishwasher Sharing Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 10:24 AM   #1
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
To know if it is legal you would need to know the amp draw on both appliances.
Old 07-08-2012, 10:30 AM   #2
Rewards Points: 1,062
Well the GD draw is variablevariable, you can trip it if you try to stuff an elephant into it.
But don't try this at home.
Old 07-08-2012, 10:34 AM   #3
k_buz's Avatar
The disposal will have a rating.
Old 07-08-2012, 10:51 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
99% of the time this it is fine on a 20A circuit. Neither is a continuous load.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
amakarevic (07-08-2012)
Old 07-08-2012, 10:54 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No, but 210.23 (A)(2) usually comes into play. A dishwasher can easily draw 11 amps.
Old 07-08-2012, 11:23 AM   #6
And a disposal runs 5-10 seconds at a time.
Old 07-08-2012, 11:28 AM   #7
E2 Electrician
I disagree, I see people leave them on for minutes... and it really doesn't matter what time frame they leave an appliance on for.
I will agree with you that "yes" it probably will work, will it meet code is the other pesky issue we have at hand.
Old 07-08-2012, 11:31 AM   #8
if someone is stupid enough to leave a GD on for minutes, they deserve to have their breaker trip.
The Following 3 Users Say Thank You to amakarevic For This Useful Post:
gregzoll (07-08-2012), oh'mike (07-08-2012), Speedy Petey (07-08-2012)
Old 07-08-2012, 11:33 AM   #9
E2 Electrician
stupid? yeah, because wiring something how someone thinks it should run should be the correct installation.
Old 07-08-2012, 11:35 AM   #10
k_buz's Avatar
You asked us for the answer. It doesn't matter how long you run the disposal for...if either one of these appliances are rated for more than 10 amps, they cannot legally be on the same circuit.
Some of these appliances require separate circuits in their instructions.
Old 07-08-2012, 11:35 AM   #11
E2 Electrician
You asked if it was code, I think i pretty much summed it up for you, why you asked is beyond me since you already know how you are wiring it.
Old 07-08-2012, 11:40 AM   #12
yeah but what are power outlets rated for ? they are not. you can plug a 16A appliance into a 15A outlet. which brings my question why the code makes demands for more predictable appliances and not for power outlets, it looks like an easy victim.
i am just asking for a rationalization of the code, that is all.
Old 07-08-2012, 11:43 AM   #13
E2 Electrician
A 16 amp cord and plug appliance will come with a 20 amp cord cap. 12 amps is the maximum cord and plug appliance with a 15 amp cord cap.
Table 210.21(B)(2)
Old 07-08-2012, 11:51 AM   #14
E2 Electrician
Im really not sure what you are trying to ask?
Old 07-08-2012, 12:26 PM   #15
Question
if you can't regulate by code what you can plug into an outlet (how many amps, that is) why is the code being nit-picky about a very nominal rating of an appliance like disposal that can maybe draw 10A once in a blue moon but most of the time will be 1-2A?
i have a MIlwaukee circular saw that is rated for 7A ... JUST TO ILLUSTRATE HOW MEANINGLESS THIS RATING IS: it all depends what you are running it against. if you put a diamond blade and try to cut some concrete with it, it will start sucking more than 15A. and is rated for 7. i have tripped the breaker this way numerous times.
i think switching the DW from the overloaded circuit to mooch off of the GD circuit will cause fewer trippings than currently
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 03:43 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 10:13 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 06:35 PM
