Old 10-05-2008, 10:10 PM   #1
Question
garbage disposal and dishwasher power
this is how i was gonna do it, please let me know your thoughts:
the power outlet for a garbage disposal and a dishwasher needs to have the tab removed because the dishwasher always needs to be hot and the disposal outlet needs to be switch-controlled.
however, is there a way to branch the circuit within the switch box so that the always hot wire somehow goes out of the switch box in addition to the disposal wire (one in, two outs) ? this may be a stupid question. what i was trying to accomplish is avoid a junction box to split the circuit before one branch goes into the switch box to control the disposal and the other straight into the outlet for the dishwasher.
Old 10-05-2008, 10:17 PM   #2
Electrician
run the feed right to the receptacle box and then just a switchleg up to the switch for the disposal.
chris75 is offline   Reply With Quote
Old 10-05-2008, 10:36 PM   #3
Question
does that mean i should have used a 12/3 cable for the circuit ? i used only 12/2.
Old 10-05-2008, 10:41 PM   #4
My License Ain't 4 Sale..
Attachment 5288
You know, I wonder, in the case of the pic, since it is a multiwire circuit, and most likely 20 amps, if a 20 A receptacle and switch would be required? We know we can use 15 A devices on 20 A circuits where more than one outlet is present. But a split wired receptacle effectively makes a duplex two single devices. And the switch is operating only one outlet.
Opinions?
Old 10-05-2008, 10:46 PM   #5
I believe the code says that as long as neither of your pieces of "utilization equipment fastened in place" exceeds 50% of the branch circuit rating, they can be on the same circuit. So in other words, your 12-2 should be fine. The 12-3 would be used to give each appliance it's own circuit.
Old 10-05-2008, 10:51 PM   #6
Question
Originally Posted by InPhase277 View Post
I believe the code says that as long as neither of your pieces of "utilization equipment fastened in place" exceeds 50% of the branch circuit rating, they can be on the same circuit. So in other words, your 12-2 should be fine. TRhe 12-3 would be used to give each appliance it's own circuit.
but, in my case, while legal, is there a way around having to have a junction box ? in other words, can i still emulate a junction box within the switch box somehow ?
thanks.
Old 10-05-2008, 11:54 PM   #7
thanks.
Yes, if the power comes into your switch, then it needs to leave on 12-3. The black and the red in the 12-3 being constant hot and switched, respectively.
Old 10-05-2008, 11:59 PM   #8
Wink
thanks, that's exactly what i was looking for
Old 10-06-2008, 04:39 PM   #9
Electrician
Opinions?
I think I would have to agree with you, its pretty clear what the code says, and I think you would have no choice but to use a 20 amp receptacle... The switch amperage is always based on actual load.
Old 10-06-2008, 04:41 PM   #10
Electrician
Thats correct, but alot of manufactures require a dedicated circuit, so....
Old 10-06-2008, 06:39 PM   #11
So true. I can't tell you how many times I've seen the Maytag Man jump out from behind a bush and kick the crap out of an electrician for that! I once worked in a house where Maytag, Whirlpool, GE and Sears got together and did a drive-by! Old man Kelvinator was driving
Old 10-06-2008, 07:35 PM   #12
Electrician
Nothing better than a 3 amp appliance requiring its own circuit...
conversion of portable dishwasher to stationary one grimsbyman Plumbing 14 02-19-2013 08:54 PM
Outlets in cabinets(micro, DW, Disposal, under cab lighting) DanBress Electrical 9 08-17-2008 05:59 PM
Air Gap for Dishwasher End Grain Plumbing 6 03-09-2008 09:25 PM
Dishwasher vent/air gap homer12 Plumbing 5 01-21-2008 12:25 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
