Garbage Disposal, Dishwasher Insullation - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 06:24 AM   #1
garbage disposal, dishwasher insullation
how do I hook up garbage disposal and dishwasher the are both wired with out an outlet would like to plase them on an outlet
Anthony Nowak is offline   Reply With Quote
Old 06-20-2011, 07:33 AM   #2
Rewards Points: 1,442
Nothing keeps you from attaching a piece of 14-2 Romex cable to the appliance junction box, attaching a plug to the other end, and plugging in the appliance to the receptacle under the kitchen sink.
But it would be better to wire it in directly. Remove the receptacle and substitute a blank outlet box cover with a single round hole in it into which you put a cable nipple to run the Romex cable through.
Old 06-20-2011, 01:09 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Let me add one more comment on this one some case you may have switched receptale which it will be one part of the receptale is hot all the time while other one is switched recetpale { that useally used for garbage dispoal }
If you see black and white et RED if red then good possiblty it is a switched conductor so if you do let us know right away.
Merci,
Marc
Old 06-20-2011, 02:31 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Unless the circuit is #12 wire.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-20-2011, 04:43 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
It would be better to buy a properly rated appliance cord with a molded plug
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
jamiedolan (06-20-2011), SD515 (06-21-2011)
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
kitchen faucet with spray nozzle, dishwasher and garbage disposal iklektic Plumbing 2 03-24-2011 11:53 PM
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 11:13 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
