Garbage Disposal - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 01:49 PM   #1
Garbage Disposal
Hello everyone. I have what is probably a silly question. I'm trying to install a new garbage disposal and purchased the three prong plug for it. However the outlet is too far away from the disposal for the plug to reach. My idea was to install a junction box. I would run BX cable from the disposal to the junction and the power cord from the junction to the outlet. Does this sound ok?
Also the power cord I purchased for the insinkerator is a 16 guage. Would I use 16 guage BX? The outlet is a 20amp dedicated circuit with 12/2 cable and is switch controlled.
Johnscott181 is offline   Reply With Quote
Old 03-27-2012, 02:13 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If your going to use the Bx cable why not hard wire the disposal with bx right to the box on the wall and cover the box with
This;
sublime2 is offline   Reply With Quote
Old 03-27-2012, 02:44 PM   #3
No reason other than I'd already been in the mindset of using the power cord to make things easier, lol. Your suggestion makes the most sense. Should I be using the 14/2 or 16/2?
Old 03-27-2012, 02:46 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
14/2 bx should be fine.
Old 03-27-2012, 02:58 PM   #5
Sorry, I've been referring to it as 14/2 but it is 12/2, I just double checked. I'm assuming that doesn't make a difference. BTW, thanks for your help.
Old 03-27-2012, 03:02 PM   #6
If it's on a 20 amp circuit 14/2 is not fine. You must use minimum 12AWG wire for 20 amp circuits.
fdiddy is offline   Reply With Quote
Old 03-27-2012, 03:06 PM   #7
Licensed Pro
Use a longer cord.
Old 03-27-2012, 03:16 PM   #8
Originally Posted by HouseHelper View Post
Use a longer cord.
I'm sure I could find a longer cord made by another company. Insinkerator says I am only allowed to use there cord or hard wire the unit with BX cable. I just wanted to do it the "right" way.
Old 03-27-2012, 03:22 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Typo....
12/2 for a 20 amp.
Old 03-27-2012, 04:15 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
BX isn't made anymore. What you are referring to as BX is now called MC or AC cable.
Old 03-27-2012, 04:47 PM   #11
Yes. Some people still use the term to refer to ac cable. One question I do have is, if the wiring to the AC cable is essentially the same as the switch controlled outlet? In other words, I can just switch out the outlet and connect it to the disposal the same way?
Old 03-27-2012, 04:57 PM   #12
k_buz's Avatar
If you are asking if you can "hardwire" the disposal the answer is usually yes. However, it seems as if your disposal specifically states that you have to use the provided cord, then you have to use the provided cord.
Your other option would be to move the outlet, to somewhere where the cord will reach. If that is what you want to do, just use the existing recept box as a j-box and install a new recept box using AC/MC cable.
Old 03-27-2012, 05:04 PM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yes, kill the power at the main box(not just turn the switch off) remove the outlet and the wires from the outlet run the BX cable through the cover(pic) with a 3/8" metal clamp another metal 3/8" on the disposal connect the black,white and grounds together in the box do the same in the disposal .secure plate to box and the plate on disposal. Turn power back on and test.
The Following User Says Thank You to sublime2 For This Useful Post:
Johnscott181 (03-27-2012)
Old 03-27-2012, 05:04 PM   #14
No. It can be hard wired. I bought the optional cord to make life easier. That was before I knew how short it is.
Old 03-27-2012, 05:06 PM   #15
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It is made,just gos by anther name now.
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 04:43 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
