Garage/Workshop Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2008, 10:28 PM   #1
Master Of Nothing
mr500's Avatar
What does it say in the code book about GFIC in a workshop. I plan on running 3 circuits for plugs. 1 down each side wall and one across the back wall. Do I need 3 GFIC, 1 on each run? How exactly does that play out with the code.
Also, are they they be connected at the start of the run OR in the middle, or does it matter as long as they are there and working??
Mike
mr500 is offline   Reply With Quote
Old 03-12-2008, 10:32 PM   #2
Master Of Nothing
mr500's Avatar
oops Thats GFCI
Old 03-13-2008, 12:22 AM   #3
Rewards Points: 2,350
Only receptacles in a residential garage need to be GFCI protected, not a workshop. Unless the receptacle is within 6' of a sink. Otherwise, it would be permissible to use standard outlets at your work bench. However, I would still recommend using GFCIs. Install them at the first outlet on the circuit, and protect the rest downstream.
InPhase277
Old 03-13-2008, 05:40 AM   #4
When is fishing season?
CowboyAndy's Avatar
So what is the criteria for something to NOT be a residential garage? What if I turn my garage into a workshop and don't park my car in there? Is it still a garage? What if it is an outbuilding that has a garage door, but has never been used as a garage but more of a workshop? Is GFI protection still required?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-13-2008, 06:11 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
They are required in a workshop, shed, potting shed, outhouse, pump house, etc, as well.
210.8 Ground-Fault Circuit-Interrupter Protection for Personnel
(A) Dwelling Units
All 125-volt, single-phase, 15- and 20-ampere receptacles installed in the locations specified in (1) through (8) shall have ground-fault circuit-interrupter protection for personnel.
(2) Garages, and also accessory buildings that have a floor located at or below grade level not intended as habitable rooms and limited to storage areas, work areas, and areas of similar use
Old 03-13-2008, 08:22 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
I have 3 circuits to my garage/workshop, and have a gfci at the begining of each circuit. I have only tripped a gfci in the shop one time.
Old 03-13-2008, 11:17 AM   #7
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You can install GFCI circuit breakers on each of those 3 circuits. Or install a GFCI receptacle outlet in the 1st location in each circuit and connect the down stream receptacles to the load terminals of that GFCI to protect those receptacle outlets. Wiring them incorrectly gives you no protection.
jrclen is offline   Reply With Quote
Old 03-13-2008, 11:19 AM   #8
CowboyAndy's Avatar
Quick question, is there a limit as to how mant receps a gfi recep can protect?
MY HOUSE OWNS ME!
Old 03-13-2008, 04:44 PM   #9
jrclen's Avatar
Rewards Points: 514
No limit
Old 03-13-2008, 04:50 PM   #10
Master Of Nothing
mr500's Avatar
Ughh. Kinda wish I would have bought the GFi breakers instead of regular ones. But then, they came with the panel as a package deal lol. Not that I cant wire the plugs in, just easier to pop in a breaker.
This stuff gets expensive fast don't it
Mike
Old 03-13-2008, 07:41 PM   #11
jrclen's Avatar
Rewards Points: 514
Mike
Yes it can get expensive in a hurry. And the GFCI breakers can be pricey also. The GFCI receptacles will do the job just fine.
Old 03-13-2008, 08:34 PM   #12
Master Of Nothing
mr500's Avatar
I guess GFCI plugs is what it will be. Ill put one on each line. rather spend that money and not burn something up.
Mike
Old 03-13-2008, 08:35 PM   #13
Master Of Nothing
mr500's Avatar
Originally Posted by jrclen View Post
No limit
I had one "electrician" make a comment that if you put too many plugs after a GFIC, one might get pre mature tripping? ANYONE ever heard of this?
Old 03-14-2008, 06:08 AM   #14
Yes, I have.
There is no legal limit, just like residential receptacles on a circuit, but there is common sense limit.
Grounded outlets, especially receptacles, have a certain amount of "leakage" to ground. This is normal. Add up too many and it is enough to nuisance trip a GFI.
Old 03-14-2008, 06:18 AM   #15
CowboyAndy's Avatar
So what is a "safe" amount?
MY HOUSE OWNS ME!
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
1 switch split receptacles Price pfister Electrical 16 05-03-2007 09:01 PM
gfci receptacles rjr Electrical 2 05-02-2007 07:16 PM
4-way circuit with 9 duplex receptacles crecore Electrical 7 09-01-2006 09:39 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
