Garage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 01:08 PM   #1
Garage wiring
Currently I have a 20 amp 2 pole breaker. One hot is feeding something I think in the dining room, the other goes to my garage. Right now the garage only has one receptacle. There is no lighting. Can I add lighting and more receptacles off the the existing receptacle? By the way my garage is detached and is about 50-60 feet from my main panel. Can someone give the newbie some advice?
gunner51 is offline   Reply With Quote
Old 09-29-2010, 01:14 PM   #2
With a detached structure you can have ONE circuit
or
a Multi-wire branch circuit (MWBC) = shared neutral
or
Feed the structure with a sub-panel
So you will need to run new wire - MWBC or a sub panel for more circuits
You can add off the existing circuit
Old 09-29-2010, 01:16 PM   #3
Garage wiring
Currently I have a 20 amp 2 pole breaker. One hot is feeding something I think in the dining room, the other goes to my garage. Right now the garage only has one receptacle. There is no lighting. Can I add lighting and more receptacles off the existing receptacle?
I live in Minneapolis.
Old 09-29-2010, 01:19 PM   #4
You can add more outlets & lights off the existing circuit
Not sure where you are located
Canada has a limit on how many you can have on one circuit
The Following User Says Thank You to Scuba_Dave For This Useful Post:
gunner51 (09-29-2010)
Old 09-29-2010, 03:23 PM   #5
To answer your question, yes you can add outlets and lights to that circuit. However, if you are planning on using the garage as a shop, with only a 20 amp service, you could easily trip the breaker and leave yourself in the dark at the same time.
hayewe farm is offline   Reply With Quote
Wiring house to garage stonehaven Electrical 7 06-02-2010 06:19 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-25-2009 11:05 PM
Wiring garage workshop Kay Man Electrical 10 08-28-2008 12:04 PM
wiring garage clive Electrical 6 08-20-2008 12:36 PM
Wiring my garage with direct burial cable? Earl Smith Electrical 3 08-10-2008 06:28 PM
