Garage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 09:07 PM   #1
Garage Wiring
I am wiring a small garage off of a panel in another garage that has a 200 amp box. From the box in the large garage, to were I want the box in the small garage is 230 ft. I want to run direct burial cable. UF-B, I think, 8-3. I want 4 receptacles in the large garage and 4 shop lights. The tools I will be using are a circular saw, bench grinder, battery charger, small hand drills, and MAYBE put in a very small window air conditioner. I will never use more than one tool at a time.
My question is, will 8-3, or 6-3, be big enough? What kind of box do I need in the small garage? Links to products to purchase would be great. Also, how many amps will I carry with each cable size over that distance.
KyThunder is offline   Reply With Quote
Old 05-15-2011, 10:13 PM   #2
Rewards Points: 1,016
I would put wires in oversized conduit rather than birect bury UF cable - don't have to trench as deeply and if you ever want larger capacity you can pull a larger wire.
Old 05-16-2011, 02:57 AM   #3
Rewards Points: 512
Do you mean that you want these receptacles and fixtures in the SMALL garage?
Old 05-16-2011, 06:06 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
I would bury 1" PVC conduit down 18" and pull in 4 runs of # 10 THWN (red, black, white and green). Run from a 2 pole 20 amp breaker in the larger garage. This is a MWBC (multiwire branch circuit) and will allow you to have 2 - 20 amp 120 volt circuits.
This is about the cheapest way to go initially but will allow you to upgrade in the future without re-digging.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-16-2011, 09:26 AM   #5
Yes, the small garage...
I think the 6-3, for that length of a run, will be better after finding a voltage drop calculator online.
Old 05-16-2011, 11:27 PM   #6
Good Gawddd.....went and bought 250ft of 6-3uf-b at a electrical supply place today and after tax it was over $900!!!!! Mannn, that stuff is high. The guy that will do the hooking it up told me to go buy a square d today??? Priced a trencher and it is $100 a day. Not bad, and, better than a shovel. Does it have to be 36" deep? From the voltage calculators online, 2 of them, I think I will have about 5% drop by the time I get to the garage. You have some suggestions, please let me know.
Old 05-17-2011, 12:24 AM   #7
24" deep for direct bury UF cable.
18" if wires and in conduit.
____________
Vince
Old 05-20-2011, 12:10 AM   #8
Question....Have my 6-3 uf-b run from garage to shed, Keep in mind its a 220ft run. Is 5% voltage drop acceptable? If it is, as some say, I can run 50 amps out of the main box in the big garage. 40 amps will be like 3.5% drop.
Old 05-20-2011, 05:33 AM   #9
Lic Elect/Inspector/CPO
Voltage drop cals can be done online. Here is the results of one, based #6, 1/2 circuit length, 240 volt single phase, 60 amp load.
The voltage drop percentage is acceptable.
Estimated Drop Volts Load At Circuit End Volts Voltage Drop Percentage
NJMarine is offline   Reply With Quote
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Wiring house to garage stonehaven Electrical 7 06-02-2010 06:19 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-25-2009 11:05 PM
Wiring garage workshop Kay Man Electrical 10 08-28-2008 12:04 PM
Wiring my garage with direct burial cable? Earl Smith Electrical 3 08-10-2008 06:28 PM
