Garage Theromastat - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 06:58 PM   #1
garage theromastat
i have a honeywell thermostat,hooking it up in the garage,i have a black&red wire which letter does the black wire go to
godsman is offline   Reply With Quote
Old 10-30-2011, 07:00 PM   #2
thermostat
[QUOTE=godsman;760372]i have a honeywell thermostat,hooking it up in the garage,i have a black&red wire which letter does the black wire go to
Old 10-30-2011, 07:03 PM   #3
Missouri Bound's Avatar
What letters are availabe on the thermostat? Is this for heating and air conditioning? Which type of thermostat do you have? Is a low voltage or a line voltage system? Can't really advise you unless you provide more informaton.
Old 10-30-2011, 07:20 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
If it’s low volt, heat only…one of the colors to ‘R’ both at the stat and the furnace, the other to ‘W’ at stat and furnace. As Missouri said, more info is really needed.
Kyle
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
