Garage Subpanel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 10:42 PM   #31
Missouri Bound's Avatar
The LB should be stamped with it's cu. in. capacity.
Old 08-21-2011, 11:03 PM   #32
Electrician
Rewards Points: 760
I would put a junction box in place of the LB if you want to make joints. I would try to avoid using the LB as a junction box, I can't give you a code reference if it is legal or not.
darren is offline   Reply With Quote
Old 08-22-2011, 12:01 AM   #33
Licensed electrician
Rewards Points: 996
Unless the LB is marked with the capacity it cannot be used as a splice point.
Old 08-22-2011, 12:04 AM   #34
Rewards Points: 518
What differentiates the ones marked versues the ones that aren't?(aside from the stamp)
n0c7 is offline   Reply With Quote
Old 08-22-2011, 09:37 AM   #35
Rewards Points: 996
Without knowing the capacity you can't calculate the fill volume. if you don't know the volume it makes it hard to know if you have room for additional conductors.
Old 08-23-2011, 01:27 AM   #36
Rewards Points: 518
Ok, luckily the ones I have are stamped with the cu capacity.
Old 08-23-2011, 09:50 AM   #37
Rewards Points: 154
i would use 6/3 teck90 and just use pvc where it will be visual, like 90 from a trench up to an lb then into the garage or house and just run the teck inside it
awdblazer is offline   Reply With Quote
Old 08-23-2011, 04:34 PM   #38
The wire described is only 3 conductor. A sub panel not in an attached building requires a 4th wire, a ground. Plus all the other sub panel NEC stipulations.
Old 08-23-2011, 05:20 PM   #39
Rewards Points: 518
PVC is already piped in undeground. City says I can run individual wires as long as I carry the ground. Will I need to run PVC right to the main box or can the wires be exposed inside the house?
Old 08-23-2011, 07:43 PM   #40
Electrician
Rewards Points: 760
If there individual conductors you can't run them exposed, they have to be in pipe. You could put a junction box where the wires come in and then use lomex to run to your panel.
Old 08-24-2011, 12:22 AM   #41
Rewards Points: 154
6/3 teck90 is 3 insulated conductors with a bare ground
Old 09-11-2011, 12:35 AM   #42
Rewards Points: 518
Back again. While researching prices I've noticed that there is alot of emphasis on temperature ratings on the cable. Any suggestions what temperature rating I should watch out for?
Old 09-11-2011, 01:15 AM   #43
Electrician
SD515's Avatar
Rewards Points: 504
Much of the wire you find will be rated 90 degrees Celsius. Usually it’s better as you can derate from the 90 degree column, though you still have to terminate using the 60 or 75 column.
Kyle
Old 09-11-2011, 01:23 AM   #44
Rewards Points: 518
Alright, I'll try to stick with 90C to keep it easier. If I do decide to transition from THWN to NMD cable in the LB at the house, what type of clamp down connector can be used? I can't seem to find a 1-1/4" plastic connector, only metal. What do you guys use?
Old 09-11-2011, 02:05 AM   #45
Sparky
Rewards Points: 510
one of these
and a short piece of pipe
Techy is offline   Reply With Quote
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
correcting existing subpanel in detached garage mtk Electrical 17 03-14-2010 02:49 PM
Legal to have subpanel in garage? gante Electrical 36 03-13-2009 04:27 PM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 12:42 PM
