-   -   Garage single gang box GFCI w/12 conductors (http://www.diychatroom.com/f18/garage-single-gang-box-gfci-w-12-conductors-146264/)
rstyszko 06-07-2012 04:32 AM
1 Attachment(s)
Please forgive some of my ignorance with residential wiring, I usually just do industrial electrical and really don't have to worry about dealing with any codes at work. What I have to do is GFCI protect all the outlets in my garage. I found one outlet that branches off to all the other outlets in my garage. If I put a GFCI on this outlet to protect it and all the other outlets, I cannot put it all back together properly because of how deep the GFCI is compared to the outlet I removed. There are a total of (x4)Hots (x4)Neutrals and (x4)Grounds[pigtailed] in the gang box. I believe all wires are #14. Should I just get a 2 gang box deep enough to fit everything in properly and replace the single gang box? Or should I get a 2 gang box and use it as a junction box in between this GFCI single gang box and all the rest of the outlets? Also, either way, on the double gang boxes, should I install rubber grommets on all the knockouts that I'm running the Romex through? May be a dumb question, but I figured I'd ask anyway. I have attached a photo so you can kind of see what I'm talking about. It's not the best photo and only 2 sets of wires are currently connected. Please let me know if anyone needs more clarification about what I'm trying to do or if any other photos may be needed.
k_buz 06-07-2012 06:47 AM
Oh come on, don't try to tell us you are an electrician when you ask this type of question.
That box is completely overfilled. You ether need to install a new, larger box or install a handy box extension.
Speedy Petey 06-07-2012 07:16 AM
I could never understand that mentality.
"I don't do resi work".
"I don't have to deal with codes".
"I believe all wires are #14".
You should have just been honest and said, I am not an electrician and don't claim to be.
Barring any codes, logic should tell you that four cables in a single gang box is way overfilled. And doing "industrial electrical work" you should be dealing with conductor size and box fill all the time. This is NOT a resi only thing.
What Kbuz said, replace the box or use an extension collar.
rjniles 06-07-2012 07:54 AM
And not many electricians would use the term "outlet" when they were specifically talking about "receptacles". To an electricain an "outlet" has a different meaning.
You do not need to GFCI protect all the outlets in your garage, you need to protect the 120 volt receptacles.
Code05 06-07-2012 10:00 AM
Could have been worse and the OP had said plugs, that really drives me crazy.
I am bored, nit pick time:
210.8 Ground-Fault Circuit-Interrupter Protection for
Personnel.
FPN: See 215.9 for ground-fault circuit-interrupter protection
for personnel on feeders.
(A) Dwelling Units. All 125-volt, single-phase, 15- and
20-ampere receptacles
installed in the locations specified in
(1) through (8) shall have ground-fault circuit-interrupter
protection for personnel.
(2) Garages, and also accessory buildings that have a floor
located at or below grade level not intended as habitable
rooms and limited to storage areas, work areas,
and areas of similar use
rstyszko 06-07-2012 02:39 PM
I am not an electrician, nor do I claim to be. Of course I realized that the box was overfilled, but my question was really directed more towards what would pass an inspection or not. I just didn't want to do the work twice.
kevinp22 06-07-2012 02:48 PM
Originally Posted by rstyszko (Post 938092)
I usually just do industrial electrical .
Could have fooled me. :no:
Of course, to a degree I sympathize. I do corporate accounting/finance and friends call me with their rental property etc tax questions and I don't even try.
Code05 06-07-2012 03:34 PM
I do not, actually I am about 80% commercial, 10% resi and 10% industrial: and for about 90% of the NEC codes-there is no distinction between them.
Now about my 401(K) and 403(B) and certain taxes.....:)
rstyszko 06-07-2012 07:36 PM
Thank you for all of your replies and help everyone. You have all been most helpful with this topic.
goosebarry 06-08-2012 04:17 PM
An outlet is where you buy your receptacles and a receptacle is where you dispose bad outlets?
