Garage Refrigerator Tripping GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 07:42 PM   #1
Noob w/ more experience
Rewards Points: 29
Hello,
I just received an older garage fridge from a friend. I just tried plugging it in and as soon as the plug hits the receptacle it trips the GFCI. I'm not an electrician but a guy who likes to do his own work around the house. What can I do to get this fridge to start working? Here is what I know, this GFCI has a strong load on it, two bathrooms, a few outdoor lights, and the whole garage. How do I make it so that the fridge can work? Or, is there something wrong with my fridge?
Thanks,
Greg
golfer2b is offline   Reply With Quote
Old 09-29-2010, 07:45 PM   #2
the Musigician
DangerMouse's Avatar
I'd dare say it's the fridge, not your electric.
Maybe a bad cord? Look for frays or severe twists?
Many other things to test if not.
DM
Old 09-29-2010, 08:12 PM   #3
Licensed electrician
Rewards Points: 1,054
GFI's do not trip due to overloads. That is the job of the breaker. GFI's trip due to an imbalance of current between the hot and neutral. Your refrigerator has a problem and need to be repaired or replaced.
Old 09-29-2010, 08:19 PM   #4
Bigplanz's Avatar
Rewards Points: 924
I also think you have a problem with the refrigerator. I've run lots of high amp and high initial surge power tools in my garage and never tripped a GFCI. The only thing that ever tripped it was a 6 inch clip on fan, when I would turn it off.
Bigplanz is offline   Reply With Quote
Old 09-29-2010, 09:17 PM   #5
" Euro " electrician
frenchelectrican's Avatar
The most common curpit is the compressor interal winding going bad that why the GFCI do trip.
But check the cord first for any visvable damage and any crack anything like that and replace it and some case it will clear up but not always.
Merci.
Marc
Old 09-30-2010, 10:16 AM   #6
First thing to do is plug the refrigerator in and reset the GFCI, it it stays reset you're good to go. Some times just inserting a plug will cause them to trip.
hayewe farm is offline   Reply With Quote
Garage GFCI Circuits H2O Engr Electrical 6 01-20-2010 08:22 PM
GFCI Outlet on 20A garage circuit campos202 Electrical 2 09-10-2009 10:38 AM
GFCI in garage? gone_fishing Electrical 6 12-28-2008 01:06 PM
Garage GFCI on Subpanel sweaty Electrical 2 09-20-2008 01:29 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 04:27 PM
