Garage Ready For Rough Inspection? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 09:51 AM   #1
I ask the impossible!
Rewards Points: 640
Garage ready for rough inspection?
Just putting up my pics that I believe should be ready to pass rough inspection. I'll be working on the main service panel this morning but if anything isn't right with the garage I'd rather fix that and not finish the service panel so I can close the wall in the garage over the weekend if I had to make a choice.
Garage ready for rough inspection?-garage-panel-ready-rough-inspection-03jun2011.jpg   Garage ready for rough inspection?-garage-panel-wall-lh-rough-inspection-03jun2011.jpg   Garage ready for rough inspection?-garage-panel-wall-rh-rough-inspection-03jun2011.jpg
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-03-2011, 10:13 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Are those boxes big enough? Did you do the wire-fill calcs? I could be wrong, but I thought a single-gang box was only used at the end of a run, there is not enough space for wires to come in and out.
hyunelan2 is offline   Reply With Quote
Old 06-03-2011, 11:45 AM   #3
Licensed electrician
Rewards Points: 1,278
You can use single gang boxes anywhere in the run as long as they are sized correctly. Some single gangs are 22 cubic inches.
Old 06-03-2011, 11:49 AM   #4
Will, one thing I noticed is that there does not appear to be a double stud next to the door. i also like to add blocking so the trim plate will clear the door trim. You can also run 2 cables into the one KO on the box. I also like to run the cables a couple of inches higher or lower than you did so there is more room to staple. I would have also run multiple cables in each hole.
I think you missed a strap on the conduit going down into the JB.
Old 06-03-2011, 11:59 AM   #5
Rewards Points: 1,574
Attached or unattached garage?
bob22 is offline   Reply With Quote
Old 06-03-2011, 12:13 PM   #6
Rewards Points: 640
I'm not overly worried about trim, I'll be covering with insulation, drywall, painting the drywall and then putting furring strips over the drywall and putting up peg board. Some day.
So this time he gave me a writeup which I'll attach below and informed me that he spoke with the building department director and he's going to charge the inspection fee each time he comes out.
1) So because the pipe for the feeder is PVC between the junction box and the panel, he wants a ground conductor. Or I can make the pipe EMT. He doesn't care that there's a ground clamp on the rigid metal. From discussions here I've been under the impression that I'm to code.
2) He says staple NM to code. This refers to where NM cable comes out of the blue boxes that have clamp tabs and go through studs within 4". Everything else was stapled at the time of inspection. He wants a staple on the NM in the 4" between the box and the hole in the stud.
3) "Make up grounds as loose". He pulled one out, pulled it apart.
4) PVC #40 not rated for use. He looked right at the PVC last time and said nothing.
5) Missing ground rod. He didn't even look when he wrote this up. 2 ground rods were installed. He said the wire has to be protected, schedule 40 isn't okay, EMT is okay. Thanks for pointing this out in the first or second inspection. Oh wait, he didn't even look.
5) Install fittings in boxes as needed. ???
6) Install KO seals as needed. I asked for an afternoon inspection, and every other time he's inspected it has been after 1 PM. Today he shows up at 11:15 and I was still in the middle of working on everything. And once again, he has never mentioned this before, and if he had and it was the only thing I'd ask if he could catch it at final since the panel is surface mounted and won't be covered.
7) reinspection fee.
I'll be talking to the director myself after their lunch hour is over. Any help anyone can offer for applicable code sections for me to refer to would be helpful please.
Old 06-03-2011, 12:14 PM   #7
Rewards Points: 640
Unattached.
Old 06-03-2011, 01:11 PM   #8
hyunelan2's Avatar
Rewards Points: 686
Re-inspection fee is typical here. Everytime the inspector has to make a visit to the site, it's another charge. Motivation to do things right the first time, I guess.
Old 06-03-2011, 01:25 PM   #9
Rewards Points: 640
I wouldn't mind the fee if not for now being unemployed and if I actually could get an inspection that was good enough to know that the inspector wasn't going to find something he could've found before but didn't bother to check.
Missing ground rods because he didn't even look. Service mast bracing because he invented his own rules out of thin air. NM stapling that isn't required by code or his own previous inspections. I don't do the whole speak to someone's supervisor thing unless it's really bad. I'm heading over there shortly.
Old 06-03-2011, 01:48 PM   #10
Rewards Points: 640
*GRR*... Being that it was memorial day week, Monday was a non-business day. Being that I knew he didn't work Tuesdays I called last weekend requesting Weds. inspection. They called and said he wasn't working that day so 2nd inspection was Thursday. I try to fix his issues and get reinspected so I can close the walls this weekend and get my parts back in the workshop so I can get my project car out of the driveway, doesn't happen...
And then after I prepare myself to talk to his supervisor, it's Friday. They close at noon.
My complaints are plenty, but I'll leave it at that.
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
