Garage Power Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 12:21 AM   #16
JuzRick's Avatar
Originally Posted by stubie View Post
I think you need to re-read the thread ...
Yeah, I see now no subpanel. Still I suggest poster consults with a qualified electrician. Better safe then sorry! :-)
JuzRick is offline   Reply With Quote
Old 02-04-2013, 12:29 AM   #17
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by shoothebunnies View Post
Went out to the garage this morning and had no lights. Checked the panel and neither breaker was tripped. Nothing plugged in. It's an old garage with one pull chain single bulb light and one outlet.
Went in the house to the main panel (runs from there to the garage) and the breaker was tripped. It occupies two slots and is 30 amp on each slot. It says internal common trip. Switched it back on and it buzzed and tripped immediately. Went back out to the garage and shut off the two breakers in the panel out there, came back in and same thing.
Can these breakers go bad?
If so are they hard to change?
Thanks in advance for your help.
Eh., Excuse moi.,, I put a underline of OP wording and Oui ., He do have subpanel in the garage.
Merci,
Marc
Old 02-04-2013, 12:41 AM   #18
JuzRick's Avatar
Merci,
Marc
Yeah, I see now after reading for the 2nd time now, lol. Post: Went out into garage breaker wasn't tripped. Still suggest consulting with a qualified electrician to isolate the problem.
Old 02-04-2013, 01:01 AM   #19
I am pretty sure it have to be underground conduit or direct buial cable that pretty much done for it.
If the OP have pretty deep frost then no doubt about it., It can do hovac on them. I have fixed them like that when frost hit them hard.
Merci,
Marc
Old 02-04-2013, 07:12 AM   #20
Rewards Points: 714
A good electrician should be able to find the short with a wire tracer, if it is a hard short. If it's a short in water or a short across a gap, the wire tracer won't locate it as easily. A DMM will tell if it's a dead short. If the short can be located, it can be spliced underground.
Mark
busman is online now   Reply With Quote
Old 02-04-2013, 08:22 PM   #21
Rewards Points: 31
Would like to thank all of you for your help in assessing the situation.
I am going to hold off until spring hits here to make things a little easier to fix.
shoothebunnies is offline   Reply With Quote
Old 02-04-2013, 10:49 PM   #22
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
On a side note, the last thing you want to do, is take the cover of the panel and try to reset a tripping breaker.
Look up arc flash and you will see why.
Garage insulation question silverfox103 Insulation 0 10-05-2011 10:10 AM
feeding power to garage beech Electrical 2 08-23-2010 08:58 PM
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 09:24 AM
Detached Garage: Design Question esemrick Building & Construction 4 01-12-2010 05:59 PM
Garage lost power jkrodger Electrical 4 11-04-2007 09:50 AM
