Garage,Patio And Porch Lights On Same Switch- HELP!! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 01:09 PM   #1
Garage,Patio and Porch lights on same switch- HELP!!
This seems to be an easy thing to do, but I want to be sure that I am doing this correctly. I would like to turn on and off the lights in the patio; garage and front porch from the same switch and at the same time install on the same switch a Honeywell RPLS540A ECONOSwitch Programmable Timer Switch to automate the sunset and sunrise lighting. I have attached a jpeg and would appreciate if someone can provide me with some advice...thanks in advance
Garage,Patio and Porch lights on same switch- HELP!!-connect-all-lights-switch.jpg
fta123 is offline   Reply With Quote
Old 08-14-2012, 01:23 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You would need to run a wire (actually 2 separate wires) to connect all three sets of lights.
Old 08-14-2012, 02:21 PM   #3
Rewards Points: 1,548
You want three switch zones, one for each group of lights, also a master switch that overrides the zones and turns on all the lights.
This is quite complex. You need a "three pole" or "three circuit" timer switch unit, or purchase three timer switches, or have a system of relays so one timer switch can turn on the three zones without connecting the zones to each other that turns it all into one zone.
Lights for porch Keith vent Electrical 2 03-26-2012 09:17 AM
Activating Two Sets of Lights with One Switch smokey847 Electrical 2 01-16-2012 11:16 AM
Porch light unpowered by separate multi-way switch S_Jeff Electrical 11 12-13-2011 06:24 PM
lighting question - porch lights / serial.? MooF Electrical 13 03-05-2010 08:48 AM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
