-   -   Garage,Patio and Porch lights on same switch- HELP!! (http://www.diychatroom.com/f18/garage-patio-porch-lights-same-switch-help-153676/)
fta123 08-14-2012 02:09 PM
1 Attachment(s)
This seems to be an easy thing to do, but I want to be sure that I am doing this correctly. I would like to turn on and off the lights in the patio; garage and front porch from the same switch and at the same time install on the same switch a Honeywell RPLS540A ECONOSwitch Programmable Timer Switch to automate the sunset and sunrise lighting. I have attached a jpeg and would appreciate if someone can provide me with some advice...thanks in advance
k_buz 08-14-2012 02:23 PM
You would need to run a wire (actually 2 separate wires) to connect all three sets of lights.
AllanJ 08-14-2012 03:21 PM
You want three switch zones, one for each group of lights, also a master switch that overrides the zones and turns on all the lights.
This is quite complex. You need a "three pole" or "three circuit" timer switch unit, or purchase three timer switches, or have a system of relays so one timer switch can turn on the three zones without connecting the zones to each other that turns it all into one zone.
