Old 09-28-2009, 06:23 PM   #1
garage panel upgrade
Im upgrading my panel in my garage from a fuse to breaker
what things should i no while doing this...i know to de ox my service cable..but what other things should i keep in mind while doing this
Tradesman14 is offline   Reply With Quote
Old 09-28-2009, 07:19 PM   #2
Xtreme DIY'r
Is it a 3 wire feed or 4 wire?
Attached garage or detached?
GFCI outlets in the garage?
De-ox - Alum wire ?
What size panel are you putting in?
Old 09-28-2009, 08:42 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Plus what more we need to know what size conductor you have exsting and type as well.
Per 2008 NEC code you have no choice but you have to run 4 conductor feeder to the garage subpanel you can not use the exsting three conductor if old style without ground if ground it may be ok but very lerry about it all it depending on what size you are increasing.
Merci,Marc
Old 09-29-2009, 12:20 PM   #4
J. V.'s Avatar
Do you plan to get a permit and have the job inspected? If the answer is yes, we will help.
We will need to know what your intentions are before we can help you.
1) Current service size?
2) Main service panel or sub panel?
3) Upgrade or just change from fuses to breakers?
Main Panel Upgrade Invisible-Man Electrical 21 08-23-2011 04:24 AM
Apartment garage breaker upgrade 1gcrazy Building & Construction 3 06-30-2009 09:48 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 08:35 PM
Breaker Panel In Detach Garage Jamn68j Electrical 2 04-25-2007 04:30 PM
Detached Garage Sub Panel MainePainter Electrical 6 08-25-2006 10:58 AM
