Garage Panel Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 10:13 PM   #1
Garage panel question?
Hi guys,
I just built a garage addition and just finished wiring the main panel.
I wired all the breakers on one side and Im wondering if this is a problem.
Just wondering if the breakers should be on both sides or does this even matter?
Thanks Mike
catch22 is offline   Reply With Quote
Old 09-21-2009, 10:15 PM   #2
What Mfg panel?
Old 09-21-2009, 10:17 PM   #3
Doesn't matter.
220/221 is offline   Reply With Quote
Old 09-21-2009, 10:31 PM   #4
Thumbs up
Originally Posted by 220/221 View Post
Doesn't matter.
It depends on the (old) manufacture. Many (30) years ago, the small FPE and GE panels would have all the breakers on one side run off one HOT leg. In the center, they'd have room for TWO 2-pole breakers. Any other spot would yield, instead of 220V. 0 Volts. Today, thankfully those products are off the market. (Eliminate Confusion) through Education!!! Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-21-2009, 10:42 PM   #5
The panel is a Federal Pioneer made by Stab-Lok with 20 spaces on each side.
Old 09-21-2009, 11:02 PM   #6
Thumbs up
Are the Breakers set in the panel VERTICALLY or HORIZONTALLY? (Switched UP and DOWN or SIDEWAYS?) If they are switched Up/Down, you only have the center (2 positions) for 220v. On the Horizontal (positioned) breakers, it doesn't matter where you stick in the breakers. (No matter what) Don't Drink and Drive, Ever!!!
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 12:28 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 04:27 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 01:23 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
