Is This Garage Panel Plan Right? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2014, 03:43 PM   #1
I ask the impossible!
Rewards Points: 704
Is this garage panel plan right?
So I have a small garage, a year or two down the road I intend to tear it down and build a larger one, but for now I want to run an overhead wire to a new panel so I can connect my air compressor (30A 2 pole) and have a 20A circuit for receptacles and a lighting circuit.
Can I use a 60A A/C disconnect at the disconnect means for a 125A Homeline main lug panel (Fed off a 50A circuit breaker in the house of course)
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-14-2014, 03:54 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Theoretically you could but I don't know if it would pass code or not. Everything would be protected by the 50 amp circuit and the 30A 2
pole and the 60A a/c would just be a switch.
Robpo is offline   Reply With Quote
Old 06-14-2014, 03:55 PM   #3
Rewards Points: 3,396
Don't see why not.
The only issue I would see is how to terminate your neutral and ground.
Ok, and maybe how you will enter it?
ritelec is offline   Reply With Quote
Old 06-14-2014, 04:36 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Why would you do it that way ..... go spend 20 bucks and get one of these.
http://www.lowes.com/pd_36242-296-HO...ductId=3134331
You can install a back fed main breaker for your disconnect in the first 4 positions or spaces 1 and 2. You will need the hold down kit for the main breaker and an accessory ground bar so you can keep neutral and ground not bonded.
An a/c disconnect has no neutral or ground provision as already mentioned ... forget it.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 06-14-2014, 06:59 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
As long as you have less than 7 breaker handles, you do not need any additional disconnect.
Coastal South Carolina
Old 06-14-2014, 07:37 PM   #6
That's right, and close to the entrance.
Never made sense to me how a detached structure would need to be able to be disconnected from an external disconnect or the panel being right inside it's entrance. Yet at the house, that main is inside the house behind locked doors usually in a corner room in the basement.
got me?
Old 06-14-2014, 10:31 PM   #7
Rewards Points: 704
That is, as a matter of fact, exactly the panel I bought. Although the disconnect was $6.80 which is less than the $8.25 of a 2 pole breaker, plus the hold-down kit is $4.98.
I'm not set on any particular course of action, I want to do something that's code compliant (of course). Coming straight into the panel from the weatherhead would be good.
Old 06-15-2014, 12:07 PM   #8
Rewards Points: 455
or this one for $16.97 http://www.homedepot.com/p/GE-PowerM...7?N=5yc1vZbm0u
Cletis is offline   Reply With Quote
attached garage sub panel readar Electrical 22 10-20-2013 07:25 PM
Add 14-50 240v 50amp plug in garage or Add entire panel and 240v plug on Old House. wowor Electrical 9 06-06-2013 02:54 PM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 09:55 PM
