Garage Outlet Location - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 12:21 PM   #1
Garage outlet location
How far from the bay door and how High off the Floor? I would like to have an outlet as close to the bay door as possible to eliminate dragging extension cords across the entire floor when vacumming vehicles in the driveway. Appreciate the feedback TY
redrumliny is offline   Reply With Quote
Old 09-04-2009, 12:32 PM   #2
Anywhere.
GFCI protected
220/221 is offline   Reply With Quote
Old 09-04-2009, 12:37 PM   #3
Originally Posted by 220/221 View Post
Anywhere.
GFCI protected
Thank you I thought that there may be a higher from the ground than normal requirement for Garages?
Old 09-04-2009, 12:45 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
My entrance and breaker box is located in the narrow wall (3' wide) between the door opening and the side wall. Original work (inspected) and looked at and inspected during recent new circuits and modifications. (last was 1 year ago). I have a 20 amp GFCI dulex out located slightly below and on the same plywood mounting board and within 1' of the overhead opening. I also have another receptacle on the the other side of the overhead door.
You are definitely right about the convenience. I also keep a coiled, unplugged extension cord near the outlet.
Dick
concretemasonry is offline   Reply With Quote
Old 09-04-2009, 12:49 PM   #5
In the garage I like the outlets about 3' off the ground
Just easier to reach
I'll have outlets spread around the 2 doors
One on each side of the garage near the doors & another on the wall between the doors
Old 09-04-2009, 04:33 PM   #6
Rewards Points: 1,016
I have two outlets near the garage door - both at about waist level to make it easy to plug/unplug items, and both dedicated 20 amp circuits.
My air compressor sits near the door using one of the circuits, allowing the air hose to reach anywhere in the garage and driveway both.
Old 09-05-2009, 12:30 AM   #7
Rewards Points: 6,652
Hip level is where I have mine. I am 6'-4", and they come out at around 42" from the floor of the Garage. It really depends on your preference, but personally I hate garage outlets that are too low (18" from floor), and ones that are out of reach (only in the ceiling, or clear across in the other bay, but none in the one that you need).
The other thought, is you may want to just look at using Shop Vac's unit that you can hang on the wall. Now, if attached Garage, what is your thought about installing a whole house Vacuum?
Old 09-05-2009, 09:53 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Personally, I'd consider putting one inside the garage conveniently located for use by the door, and put one outside (GFI'd/in-use cover) for use in/near the driveway.
Kyle
Replacing Garage Outlet CIAlias Electrical 5 05-22-2009 03:50 PM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 01:40 AM
New coaxial outlet location shimkc Home Theater 1 01-03-2008 10:55 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 11:32 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
