Garage Lights Turn On Automatic But Also Have An Independent Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 01:07 PM   #1
Garage Lights Turn on Automatic but Also Have an Independent Switch
Like most garage door openers my garage door light comes on when it opens, and stays on for about 30 seconds. I am installing 6 Maxcor DLR56 LED Lights 15 watts per light to replace an existing fluorescent light.
How can I wire an independent switch to turn the lights on at anytime, but also continue to have the lights to come on and turn off each time the door opens?
Thus, when the doors opens, all lights stay on for about 30 seconds and then turn off, but I want to also be able to go back to the garage and turn on a light switch that would keep lights on until I turned them off.
morrisg is offline   Reply With Quote
Old 12-28-2013, 04:23 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Install a motion sensor switch for the new lights. The switch will sense the door opening and turn on the lights.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-28-2013, 08:14 PM   #3
Thank you for your prompt reply. I think you are correct about the motion sensor. I realized I was probably trying to make something overly complicated with there was a much simpler ans straight forward solution, such as you suggested.
Appreciate your time. I do plan on running down the best manufacturer and going with what you said.
Old 12-28-2013, 10:25 PM   #4
Msradell's Avatar
Rewards Points: 262
Most normal motion detectors use infrared to detect movement. Since the door is basically the same temperature as everything else a motion detector may not be able to detect the movement of the door.
Msradell is offline   Reply With Quote
Old 12-28-2013, 11:39 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,496
Whats wrong with a SPDT switch,
one position goes external supply
And the other position goes to door supply
Easy as !
dmxtothemax is offline   Reply With Quote
Tags
electrical switch , garage lighting , wiring
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 11:37 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
