Old 06-20-2005, 09:38 PM   #1
garage lights
I am preparing to wire three sets of two strips of t8 96in. flouresent lights, I want to use three different switches, Iam using #12 romex. as long as I don,t overload any circuts can I pig tail the incoming power from one switch to another?
Thanks.
kelr is offline   Reply With Quote
Old 06-20-2005, 11:31 PM   #2
Electrical Contractor
garage lights
Are all 3 switches going to be in the same box? If so then you can pigtaill all the hots and run a hot to each switch. Wire nut all your neturals. Connect all your grounds. Run your switch legs and you should be fine. T-8's do not pull much power. Is the exsiting circuit protected by a 15 or 20 amp breaker?. If it is a 15 amp breaker, then you can use 14 gauge wire.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Lights for a garage? stagger19 Electrical 8 01-16-2007 06:58 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
