-   -   garage lights (http://www.diychatroom.com/f18/garage-lights-730/)
kelr 06-20-2005 09:38 PM
garage lights
I am preparing to wire three sets of two strips of t8 96in. flouresent lights, I want to use three different switches, Iam using #12 romex. as long as I don,t overload any circuts can I pig tail the incoming power from one switch to another?
Thanks.
jbfan 06-20-2005 11:31 PM
Are all 3 switches going to be in the same box? If so then you can pigtaill all the hots and run a hot to each switch. Wire nut all your neturals. Connect all your grounds. Run your switch legs and you should be fine. T-8's do not pull much power. Is the exsiting circuit protected by a 15 or 20 amp breaker?. If it is a 15 amp breaker, then you can use 14 gauge wire.
