Old 03-19-2008, 01:46 PM   #1
Git
Garage Lights
In my old garage, pic below, I hung three, 4' fluorescent lights in the bottom of the upper cabinets, which I built using a 2x4 frame. I had some j-boxes in the wall underneath the peg board where I did the wiring for the lights. The J-boxes were mounted flush with the drywall, but I could still access them if I removed the peg board, which was held in place with several screws.
In my new house, I would like to build a similar setup, but I now have access to some attic space above where the workbench will be. Instead of installing the j-boxes in the wall under the pegboard, I would rather place a j-box in the attic and run down the inside of the wall with some 14-2. The 14-2 would come out in the bottom frame of the cabinet and run directly into the light where it would be hard wired, in place of the regular cord.
Would there be a problem in doing it this way?
Git is offline   Reply With Quote
Old 03-19-2008, 02:36 PM   #2
J Calvin Construction
jcalvin's Avatar
Garage Lights
As always, you will need to check local code. If you can readily access your junction box from the access, that would be fine. I would rather had that done than the boxes behind the pegboard. I can tell you from experience that the guy that buys your old house may hire an electrician to fix a problem and spend hours looking for the boxes behind the pegboard.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-19-2008, 05:35 PM   #3
Master Of Nothing
mr500's Avatar
Garage Lights
Whaoo thats a clean bench. Looks as if you never use it lol. Looks good and neat!!
mr500 is offline   Reply With Quote
Old 03-19-2008, 08:12 PM   #4
electrical contractor
Garage Lights
Makes me feel bad about the way my work bench looks.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-19-2008, 08:48 PM   #5
When is fishing season?
CowboyAndy's Avatar
Garage Lights
If I could only be THAT organized!
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-20-2008, 02:03 AM   #6
Git
Garage Lights
Well, thanks for the help and the kind words
The workbench didn't usually look like that and I found out over the years I had to hang my tools up so that I could see them or they would end up getting lost, never to be found again...
Old 03-20-2008, 09:23 AM   #7
electrician
Garage Lights
The only "workbenches i've seen that look like that are in the garages of retired folk This is what I thought a work bench looked like, or is this just me?
Silk is offline   Reply With Quote
Old 03-20-2008, 09:30 AM   #8
Beer Advocate
Taipans's Avatar
Garage Lights
I am so freaking jealous right now. I don't even have the room for that massive of a work bench.
Taipans is offline   Reply With Quote
Old 03-20-2008, 09:25 PM   #9
Union Electrician
goose134's Avatar
Garage Lights
Silk, it's not just you. I too have a basement full of "just in case". My workbench looks a lot your photo.
goose134 is offline   Reply With Quote
Old 03-20-2008, 09:35 PM   #10
" Euro " electrician
frenchelectrican's Avatar
Garage Lights
Don't feel bad either my workshop is pretty packed as well with combation of electrical part and diesel engine parts stacked up [ sure i do fix generators that why i get bunch of diesel engine parts ]
Merci,Marc
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Lights for a garage? stagger19 Electrical 8 01-16-2007 06:58 AM
garage lights kelr Electrical 1 06-20-2005 11:31 PM
