Garage Lights - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 10:35 PM   #61
Originally Posted by Missouri Bound
How heavy is that fixture? Could it be pulling the box out or bending the bracket?
Same if not lighter than old one.
dinosaur1 is offline   Reply With Quote
Old 06-18-2012, 05:23 AM   #62
Rewards Points: 3,256
Originally Posted by dinosaur1 View Post
Also the light fixture box isn't too tight. It moves around.
This may be your entire problem depending on why it is loose and how it's mounted. See if you can tighten it up.
zappa is offline   Reply With Quote
Old 06-18-2012, 08:06 AM   #63
Missouri Bound's Avatar
Do you want it your way or the right way?
Old 06-18-2012, 08:25 PM   #64
Generally are garage fixtures smaller than the front porch and patio fixtures?
Old 06-18-2012, 09:10 PM   #65
My garage mounting plate is the normal 6 3/4 inches. My porch and deck have a much bigger wooden mount. This bigger fixture has a wall plate that measures 7 inches up and down so although I wanted it for the garage it wouldn't fit on the mounting plate. Do people usually have smaller ones on their garage anyway?
Old 06-21-2012, 07:30 AM   #66
All set!
Fluorescent lights in the garage do not all turn on noone Electrical 8 07-01-2011 09:51 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 01:08 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage Lights Git Electrical 9 03-20-2008 08:35 PM
