Garage Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 05:20 PM   #16
Originally Posted by stickboy1375
Yes, they went to extreme when caulking by the way.
Should it be caulked at all?
dinosaur1 is offline   Reply With Quote
Old 06-11-2012, 05:23 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I just worked with some fixtures that the bases were required to be caulked according to the instructions.
Old 06-11-2012, 05:24 PM   #18
I thought they need it otherwise water can get in.
Old 06-11-2012, 05:26 PM   #19
k_buz's Avatar
On a flat surface, I normally don't use any caulk and this was the first time I have seen a requirement for caulk.
Old 06-11-2012, 05:31 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You may want to check out 410.4 (A) The only way I see to meet this requirement is to caulk....
Old 06-11-2012, 05:37 PM   #21
I have a few options. Find and replace he fixture with the same kind and/or put a cage around it or find a new fixture all together, but then I would have to replace both on my garage the same way.
Old 06-11-2012, 05:37 PM   #22
k_buz's Avatar
I don't see a 410.4
Old 06-11-2012, 05:40 PM   #23
k_buz's Avatar
Found what you are referring to...410.10
Interesting that of the hundreds I've installed...I've never been called on it.
Old 06-11-2012, 05:41 PM   #24
E2 Electrician
Sorry, I was using my 2005 NEC, thats what edition Connecticut is on.
Old 06-11-2012, 05:41 PM   #25
I even considered a wallpak light fixture, but that wouldn't look right for our house.
Old 06-11-2012, 05:42 PM   #26
E2 Electrician
I'd be lying if I told you I caulked... I guess thats why I brought the comment up to begin with, I was surprised to see the fixture caulked.
Old 06-11-2012, 05:44 PM   #27
E2 Electrician
yeah, i wouldn't go with that either.... just replace the fixture with a less expensive brand in case it gets hit again... no big loss at that point.
Old 06-11-2012, 05:49 PM   #28
What about trying Goop glue to put it back together minus the piece that is missing.
Old 06-11-2012, 06:18 PM   #29
k_buz's Avatar
Doubt it would work.
Old 06-11-2012, 06:23 PM   #30
I just looked. It can't connect enough towards the top.
Fluorescent lights in the garage do not all turn on noone Electrical 8 07-01-2011 09:51 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 01:08 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage Lights Git Electrical 9 03-20-2008 08:35 PM
