Garage Lighting Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 07:20 PM   #1
Rewards Points: 152
The lighting in my garage is pretty lacking.
I have 2 single bulbs (one per junction box) and a 3' fluorescent tube with a melted ballast (another junction box), all on the same circuit.
My question is a stupid/simple one. Can I replace what I have with fixtures containing 2-4' fluorescent tubes without overloading the circuit (Circuit has a 15A breaker).
Using the equation power = voltage x current (and conversely, current = power / voltage) I get:
Power = 32W x 6 tubes = 128W
Voltage = 120V
Current = 128W / 120V
= 1.1A
According to the calcs, it looks like I'm good to go but I might be right out to lunch. Thought I'd better check with the experts first!
Thanks in advance!
burnt03 is offline   Reply With Quote
Old 10-13-2009, 08:15 PM   #2
15amps is good for up to 1800 watts, so you are fine with that small amount.
Plumbvoltage is offline   Reply With Quote
Old 10-13-2009, 08:26 PM   #3
Residential Contractor
All looks great as long as those lights are the only thing on that particular circuit.
rselectric1 is offline   Reply With Quote
Old 10-13-2009, 08:31 PM   #4
I'm going with 6" cans & 13w CFL reflector bulbs in my garage
I did a test setup in my great room & they really put out a lot of light @8' up
Old 10-13-2009, 08:35 PM   #5
Can lights look awesome in garages! (Must be a guy thing). Depending on the weather, they are much better than fluorescents as long as you install enough of them.
Garage Door Replacement? gone_fishing General DIY Discussions 9 07-11-2009 09:37 AM
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 01:53 PM
Lighting in my garage? wibass Electrical 5 05-20-2009 11:44 PM
lighting a garage chatterbass Electrical 13 11-19-2008 10:16 PM
