Garage Lighting??? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 12:02 PM   #1
Garage Lighting???
I'm almost done mudding my 2 car garage and am getting ready to install a load of light fixtures.
How much light should I need in a small (21' x 23') garage w/ 10' ceilings?
I was thinking eight 2-tube t12 4' fluorescent fixtures. Is this overkill?
Would it be worth spending $80 more to get t8's instead of t12's??
What about can lights instead??
PS- I plan on using the garage to finish building and working on my street/strip hotrod.
mopowers is offline   Reply With Quote
Old 01-20-2010, 12:19 PM   #2
Weekend Warrior
Eight 2-tube 4' lights is the minimum, using the simple 1 watt of fluorescent light per square foot guideline.
H2O Engr is offline   Reply With Quote
Old 01-20-2010, 12:26 PM   #3
I'd go with T-8's
Is there specific area where the car will be while you work on it ?
One issue is the hood will usually block a lot of light
Some people have mounted a set of lights at an angle on the ceiling to direct lights down & under the hood
Others use a portable light setup for more light
Old 01-20-2010, 02:45 PM   #4
Rewards Points: 1,016
I have a 24x30 workshop with 8' ceiling. General lighting is provided by six 4' two bulb flourescent fixures. A corner work bench gets another same light fixture directly overhead, as does a assembly bench floating in the room. Also there are two reeled worklights that hang from the ceiling - at the ready to be pulled down and put direct light where needed.
How much lighting for garage dizzy46 Electrical 18 12-23-2009 11:07 AM
garage lighting handifoot Electrical 10 07-27-2009 11:11 AM
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 12:53 PM
Lighting in my garage? wibass Electrical 5 05-20-2009 10:44 PM
lighting a garage chatterbass Electrical 13 11-19-2008 09:16 PM
