Garage Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 10:55 AM   #1
Rewards Points: 150
garage lighting
I have an unfinished garage. I will most likely put up drywall some day but the ceiling will no doubt always be open.
I want to re do some basic lighting. Question is, do I need to run the romex in conduit across the ceiling beams, or can I just staple it to the underside of them. These ceiling beams are 12 feet above the floor. Thanks
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 07-26-2009, 01:28 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
If you have room above the garage, like an attic space, run your lines up there and run them close to where the rafters meet the floor joists. This will avoid any physical damage issues to the cables.
Otherwise, you have to drill holes in the joists. Stapling them directly to the underside of the joists is an NEC violation.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 07-26-2009, 02:04 PM   #3
I would use BX cable.
Last edited by Scuba_Dave; 07-26-2009 at 11:51 PM. Reason: removed false statement
Conrads is offline   Reply With Quote
Old 07-26-2009, 02:07 PM   #4
If you are not storing anything up there, run the BX cable along the top of the rafters. (BX cable is the copper wire with the aluminum covering)
Old 07-26-2009, 02:41 PM   #5
Rewards Points: 150
I do have some plywood laid across the top and am storing some stuff up there. So would that mean I should use something like BX on the sides or across bottoms of the joists?
Warren Zevon
Old 07-26-2009, 02:52 PM   #6
Yes. Just staple them to the sides of the joists.
Old 07-26-2009, 09:43 PM   #7
Electrical Contractor
jbfan's Avatar
If romex is allowed in you're area, why would you use bx?
Not using bx will not burn down the garage!
jbfan is online now   Reply With Quote
Old 07-26-2009, 10:04 PM   #8
The casing is harder to peirce then the casing on romex...plastic verses aluminum....duh....Conuit is overkill but definatly even better..
Old 07-26-2009, 10:20 PM   #9
Rewards Points: 1,016
Just staple to the side of framing members and you will be fine. You do not need BX cable or conduit.
Old 07-26-2009, 11:50 PM   #10
The point is you are telling someone they are risking burning down their garage by using NM which is completely false
Old 07-27-2009, 12:11 PM   #11
No I wasn't...I just meant..better safe than sorry..in the attic of a garage you are constantly shoving things in the rafters..if you slide something across regular wire, it could slice through the casing...that's all I meant..God..what's with the egos on this site...I was just trying to help...won't be returning to this site.
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 01:53 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Lighting in my garage? wibass Electrical 5 05-20-2009 11:44 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
lighting a garage chatterbass Electrical 13 11-19-2008 10:16 PM
