Garage Light Situation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 12:13 AM   #1
Rewards Points: 308
In our detached garage, we have a wall sconce between the doors. This is rigged to the garage opener by placing a socket-to-receptacle converter in the socket for the light in the opener, which is connected to the outdoor sconce, thus, turning the outside light on when the door is raised, someone crosses the lasers, etc. I am aware this is completely rigged and likely a fire hazard--this is why I am posting.
I would like to be able to turn on the light from a switch I install, but also for it to activate with the garage door. Any way of doing the two of these?
smokey847 is offline   Reply With Quote
Old 05-31-2012, 12:25 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I can think of a decent way to do it. It would include a 120V photocell and motion sensor.
1) Bring power to the switch box for your switch.
2) Run straight power to a photocell on the outside of the garage from the switch box
3) Wire a ceiling mounted motion sensor to the load side of the photo cell and mount it above the door when it is raised
4) Wire the light fixture to the load side of the motion sensor
(The photocell will only allow the motion sensor to turn the light on when it is dark out)
5) Run a normal switch leg to the light fixture
At the light fixture you will have three wires in the splices. The switch leg from the switch, the switch leg from the motion sensor, and the wire from the light fixture.
Old 05-31-2012, 11:49 PM   #3
Rewards Points: 240
An alternative to motion sensor, if you didn't mind hacking into your garage door opener, would be to wire a relay into its light circuit. This would probably void the warranty, but it's doable.
I will note that this is the sort of thing that home automation systems can do in a snap. IMO more people should have one.
fa_f3_20 is offline   Reply With Quote
Old 06-01-2012, 12:07 AM   #4
Rewards Points: 308
I'm not opposed at all--please explain a bit more please.
Old 06-01-2012, 07:20 AM   #5
joed's Avatar
Rewards Points: 12,852
No need to hack into the opener circuit just get a screw in adapter for light socket.
Old 06-01-2012, 09:25 AM   #6
Rewards Points: 308
Thats what I currently have but I would also like to be able to turn it on from a switch as well.
Old 06-01-2012, 09:39 AM   #7
Rewards Points: 826
Put one of these relays at the switch box with NO contacts in parallel with the manual switch. Then run low 24V line from coil side of relay to the GD opener. Put a bulb to plug adapter (as shown in #5) in one of the bulb spots. Then plug in a cheap 24 V "wall wart" transformer and connect with LV wiring back to the relay coil.
Now external lights will be on if either the switch is on or the GD opener light is one. Since the RIB is UL listed and mounts in a knockout of the switch box this would be code compliant.
http://www.functionaldevices.com/bui...model=RIB2401B
curiousB is online now   Reply With Quote
Old 06-01-2012, 11:52 AM   #8
joed's Avatar
My GDO has a work light switch on the manual panel. I can turn it on/off anytime without opening the door.
Old 06-01-2012, 11:57 AM   #9
Rewards Points: 826
Most if not all do.
I think the point here is that in addition to being able to manually turn on garage lights you can also have the entire garage light up when the door opens. Particularly valuable in multi-car garage where the GDO light only illuminates the bay opened. If you use the GDO to turn on a relay all the lights in the garage can come on, including lights in front of garage.
Old 06-01-2012, 12:08 PM   #10
joed's Avatar
Use a motion sensor switch. I don't like the idea of modifying GDO to direct connect to house wiring.
Old 06-01-2012, 01:28 PM   #11
Rewards Points: 826
To each his own.
The solution I outlined doesn't modify the GDO. It just re-purposes a light bulb holder to drive a relay. The modifications are on the home wiring front by adding the relay. It isn't direct connect either since there are two cascaded isolation points; 1) the small transformer plugged into the bulb adapter at the GDO and 2) the relay (a UL approved device) mounted at the switch location. There is plenty of electrical isolation between these two devices.
Old 06-05-2012, 10:42 PM   #12
Rewards Points: 308
CuriousB,
Where could I purchase one of these relays, and what exactly is it called? It does't appear for sale on the site you listed--i'd love to buy locally.
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Garage light circuit issue Uncle Ben Electrical 15 03-02-2012 01:00 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Need new light in garage ryanuni Electrical 3 12-16-2009 10:16 AM
garage door open light deck hand Electrical 3 01-22-2008 08:29 AM
