-   -   Garage light ballast replacement. (http://www.diychatroom.com/f18/garage-light-ballast-replacement-161234/)
bdresch 10-26-2012 02:30 AM
I have 2 big 8' double lamp fixtures in my garage. They originally came out of an old outdoor sign. The ballast on one recently gave out. Its an Advance RS-2S110-2-TP. A google search revealed its an old magnetic ballast and discontinued. Does anyone know what I should be replacing it with?
ToolSeeker 10-26-2012 10:23 AM
This is one time I think the big box store can help you. Just go in and tell them you have a fixture with 2 8' tubes and they can get you the right ballast.
user1007 10-26-2012 12:31 PM
Plan on spending a day and discussing your challenge with a minimum wage apron person with a caught in the headlights look on their face at a box store. I think you would do better at an electrical supply company.
By the way, I did a quick search for your ballast unit on Google and a bunch of possibilities popped on my machine!. I used "Advance RS-2S110-2-TP Ballast Replacement" for the search string.
frenchelectrican 10-27-2012 02:14 AM
That is 8 foot HO ( high output ) ballast and unforetally you will not find maganic ballast anymore so there is a electronic verison of this one.
The electronic verison will be much less noisy than the old school ballast so the humming sound will pretty much disappar. ( the lamps will look little brighter due it will useally not flicker much at all )
Not all the big box store will stock this. If they don't have it then go to electrical supply centre they will have this in stock.
Follow the ballast wiring diagram very carefull when you replace them and make sure you use the correct voltage for the ballast due there are some of them are set up for 120 volts and some are for 277 volts ( commercal building ) and multi voltage verison.
Merci,
Marc
kbsparky 10-27-2012 06:12 AM
One replacement for this is:
Advance/Phillips ICN2S110
Note that there have been occasions where I bought a whole new fixture, and robbed the ballast out of it. Cheaper than the replacement ballast by itself.
JasperST 10-27-2012 07:43 AM
I recently had one go out at a plant and found out it was 8 cents more to replace the whole fixture as opposed to getting the electronic replacement ballast alone.
user1007 10-27-2012 10:08 AM
It is wasteful and a shame bit it is true the a whole new feature may be the same or just a bit more than a new ballast.
And although still pricey, LED tube arrays are getting brighter and are availed in more color temps and some with nice color rendering indexes. Some work off existing ballasts for power but many/most do not require them. You might think of converting your fixture to LED?
ionized 10-31-2012 07:50 PM
There are too many options. The easiest best option is to replace the ballast with a t8 instant start and buy two T8 tubes. Save the old tubes for the other fixture. I would not like instant start for residential, though. I am converting some of my 17.
Ballast: http://www.ebay.com/itm/Sylvania-QHE...item2566e196b2
Second, buy new fixtures, but that is expensive and you get crappy ballasts
Third, buy retrofit kits for 4-tubes/luninaire, Simkar RFC, about $25 plus ballasts. Ebay for programmed start ballasts
Fourth, buy brackets, ballasts, sockets and lamps and convert them inexpensively, but it will take you some time.
Ballasts, ebay
goodmart.com
warehouse-lighting.com
bdresch 10-31-2012 10:28 PM
Would I gain anything by going from my T12ho to a T8? These are in an uninsulated garage that can get down well below 0F in the winter.
k_buz 10-31-2012 10:29 PM
You will probably need to replace the pin sockets if you make that change. High Output lamps have a exclusive pin configuration.
flasherz 10-31-2012 11:33 PM
Every LED tube light that I've found that claims to work with a ballast does not. When I contact the manufacturer, they say "oh, they only work with a very, very few ballasts". I have had to rework all the fixtures.
The best reason to go to the LED's is getting rid of the UV fade that comes from fluorescent bulbs.
Slightly off-topic, but if you have found an LED tube manufacturer that makes a tube that actually DOES work with a T12 or T8 ballast, link?
fr@nk 11-01-2012 10:59 AM
Are electronic ballasts suceptable to the same problem as magnetic ballasts in cold weather? I have an unheated garage and never used fluorescent lights as the temp can get between -10 to 5 F in my winters!
ionized 11-01-2012 12:59 PM
With regular, non-HO lamps, T8 and T12 use the same sockets, i believe, across the range of linear and U lamps so you can convert by just changing the ballasts and lamps. I know nothing about HO sockets except that they are different and have disconnects in them like the slimline sockets. If you are lucky,maybe they are the same too.
T8 lamp output fades less than T12s , but 1:1 substitution of T8 regular will yield less light than T12 HO. You could get some high ballast factor ballasts to boost output from "regular" T8 somewhat or use HO T8 if you want the most light. If you need new sockets, costs may be higher because, again, the parts (sockets) be less available. I tried to find common, unshunted, T12/T8 sockets locally and could not find them on the shelf or even orderable for a reasonable price ($4 each) so I internet ordered some and will get some more that way. I suppose HO sockets might be more common.
The T8 ballasts that I use,and most that I have looked at are rated to strike down to 0 F with "normal brightness" tubes, but maybe not lower output tubes. You have to check the manufacturer's specs. If you want lower temp performance, you might have to go to ballasts for refrigerated applications. I have no idea what these do at higher temperatures so beware if you walk into that arena. Since they are a lower volume item, I am sure that they cost more too.
All of the LED retrofits for fluorescent that I have seen advertised make you wire them directly and bypass the ballasts. The independent tests that I have seen say that they perform poorly in luminaires designed for fluorescent tubes. My knowledge could be out of date. LED luminaires of the linear fluorescent style can work well in the right application.
