Garage GFI Help Please - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 05:03 PM   #31
Well guys here is what I did and now all is well and everything is up and working again...a electrician at work told me to take the black lead and plug it into one of the other breakers that is working properly and see what happens...did that and everything was perfect...I then moved the original breaker down 1 slot in the box, hooked the hot back up to it and everything is working as it should..test works on GFI and resets. Air Compressor runs on it with no problems...Thanks to everyone for all your guiadance...Paul
ashnic is offline   Reply With Quote
Old 03-07-2011, 07:16 PM   #32
Rewards Points: 530
So there was a bad spot on the bus?
Anyway, glad you got it working.
Old 03-07-2011, 07:30 PM   #33
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm trying hard to understand how doing anything in the panel would change anything. The gfci would either have power or it wouldn't .. anyway current leakage line side of the gfci (from the gfci to the panel) is not monitored by the gfci.
Now you could explore if some how bonding in the panel was not correct and a hot to ground fault existed and would back feed the egc of the gfci branch circuit and by moving the hot wire you corrected the ground fault issue. But even backfeeding the gfci metal yoke over the egc would not trip it.
A bad spot on the bus the breaker plugged on to would do nothing as a cause for tripping the gfci.
Somewhere something is missing .....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-07-2011, 07:44 PM   #34
Licensed electrician
Rewards Points: 1,026
Like Stubbie I don't see how moving the breaker to a different spot made this work unless this was part of a MWBC and it was somehow backfeeding from the other leg of the panel and causing a short.
Old 03-08-2011, 01:10 AM   #35
Semi-Pro Electro-Geek
Rewards Points: 2,858
Just because it works doesn't mean it's right or safe. There's something strange happening here. It's really hard to say exactly what, but it's not normal.
mpoulton is offline   Reply With Quote
Old 03-08-2011, 10:38 PM   #36
I'm not an engineer but is it possible that by moving the breaker you put it on a different phase? There could be a problem with one hot leg in the panel and not the other. I wonder if an voltage drop on a phase would cause havoc with a gfci?
Jj375 is offline   Reply With Quote
Old 03-09-2011, 11:32 AM   #37
Electrician
SD515's Avatar
Rewards Points: 504
I agree
Kyle
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
