Garage GFCI Wont Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2016, 05:08 PM   #1
Rewards Points: 398
Garage GFCI wont reset
Hello,
A few months ago, our garage GFCI wouldn't reset after a rain storm which was annoying because both GDO outlets are tied into it.
I replaced the GFCI thinking it was bad (original from when the house was built in 2000). This fixed the issue and it reset fine and has been working well for the past few months.
Today we had a decent rain storm and it tripped. I tried resetting it and it immediately trips 5 seconds later.
The circuit goes Garage wall GFCI (TP) -> GDO 1 -> GDO 2 -> Single basement outlet -> back yard outlet (TP/WR) -> front yard outlet (TP/WR).
The only 2 spots I can see possibly getting wet are the front and back yard outlets but both are Weather Resistant and have newer covers.
I opened all but the GDO outlets and they all appear dry yet the GFCI keeps tripping.
The one back yard outlet had a tiny tiny knick in the neutral wire which I taped with white electrical tape. Hot looked ok though.
Any ideas?
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 02-16-2016, 05:12 PM   #2
Short Circuit
Rewards Points: 52
Did you try unplugging the GDOs and see if you can reset ?
emtnut is offline   Reply With Quote
Old 02-16-2016, 05:32 PM   #3
Oso954's Avatar
Rewards Points: 1,114
I would temporarily disconnect the feed to the outdoor receptacles at the basement receptacle.
If the GFCI will reset, you will know the problem is somewhere outdoors.
Oso954 is online now   Reply With Quote
The Following 3 Users Say Thank You to Oso954 For This Useful Post:
47_47 (02-16-2016), gregzoll (02-16-2016), joed (02-16-2016)
Old 02-16-2016, 05:37 PM   #4
joed's Avatar
Rewards Points: 12,874
What oso954 said, agree 100%.
Old 02-16-2016, 09:24 PM   #5
Rewards Points: 398
Should have read this first.
That makes sense to try - however, after waiting a little while from putting both OD plugs back together from inspecting them the GFCI stayed on (for now). It seems like this issue only happens after a good rain which is why I'm almost certain they are the culprit.
But now I can't test per above since it has been staying on. I guess I will have to wait until next time?
FWIW both GDO are less than a year old so I don't believe they could be the root cause.
Old 02-16-2016, 10:40 PM   #6
joed's Avatar
Or try squirting them with the hose.
Old 02-16-2016, 11:38 PM   #7
Rewards Points: 398
Just went out and checked and sure enough it tripped again... I'll try unhooking the outdoor outlets tomorrow and see what happens, or I may wind up calling an electrician - I've been chasing this issue for a while now and it's getting frustrating.
Old 02-17-2016, 07:01 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 1,696
My guess is a ground fault - probably at your outdoor devices. I recently went through the same exercise with a new outdoor Christmas decoration (wireform moose with lights). Determined it would trip GFCI only during rain or wet snow and eliminated cord connections, etc. The moose went back.
lenaitch is offline   Reply With Quote
Garage Door opener on GFCI partner Electrical 31 01-06-2016 04:46 AM
Unable to reset new GFCI thomasrules Electrical 27 05-21-2015 01:04 PM
gfci will not reset mattlreese Electrical 10 05-27-2014 10:02 AM
Garage Door GFCI jamiedolan Electrical 7 07-31-2011 09:14 PM
Garage GFCI Circuits H2O Engr Electrical 6 01-20-2010 07:22 PM
