Garage GFCI Keeps Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 12:28 PM   #1
Garage GFCI keeps tripping
Hi all, I have a 20A GFCI in my garage. I have a refrigerator in my garage connected to this GFCI...Actually all the outlets in the garage are protected by the GFCI. For the past year or so, since I got the fridge, the gfci will trip and the frigde will turn off. I have to go the GFCI and press the reset button. We were on vacation recently and got back to find everything in the freezer went bad. I'm not sure why this is happening? I'm not sure if it's the GFCI or the fridge, although I don't think it's the fridge...could the GFCI be bad? Should there not be a GFCI in the garage in the first place?
faromic is offline   Reply With Quote
Old 08-30-2011, 12:38 PM   #2
Code05's Avatar
Rewards Points: 1,104
GFCI could be bad or an older fridge will leak current and trip a good one.
Replace GFCI, if it still trips, replace fridge.
Code05 is offline   Reply With Quote
Old 08-30-2011, 01:16 PM   #3
Rewards Points: 6,652
Also, your garage door opener could be leaking current, if the outlet that it is plugged into, also is downstream of the gfci.
Old 08-30-2011, 01:28 PM   #4
I'm not sure if this is doable because of code requirements, but, can I replace the GFCI with a standard 20a outlet? the breaker at the panel will still protect the circuit, no? Are GFCI's required in garages by code?
Old 08-30-2011, 01:35 PM   #5
Code05's Avatar
Yes.
210.8 Ground-Fault Circuit-Interrupter Protection for
Personnel.
FPN: See 215.9 for ground-fault circuit-interrupter protection
for personnel on feeders.
(A) Dwelling Units. All 125-volt, single-phase, 15- and
20-ampere receptacles installed in the locations specified in
(1) through (8) shall have ground-fault circuit-interrupter
protection for personnel.
(1) Bathrooms
(2) Garages, and also accessory buildings that have a floor
located at or below grade level not intended as habitable
rooms and limited to storage areas, work areas,
and areas of similar use
Old 08-30-2011, 01:41 PM   #6
Ok, thanks.. I will switch out the GFCI and see what happens. Also, I forgot to mention that the fridge is about 15 years old, which is why I've been suspicious of it from the beginning.
Old 08-30-2011, 04:23 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
That's a good place to start!
Old 08-30-2011, 10:45 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,498
If you remove main gfci,
then put a portable gfci on the fridge only,
then leave it for a few days,
if it trips, then that tells you,
that the fridge is leaky.
dmxtothemax is offline   Reply With Quote
Garage Door GFCI jamiedolan Electrical 7 07-31-2011 09:14 PM
GFCI problems...replacing an old one...now tripping. ams4life Electrical 7 06-17-2010 06:10 PM
Random GFCI tripping, Data Rack theatretch85 Electrical 5 07-10-2009 08:20 PM
GFCI on generator tripping; home backup MrNeutron Electrical 21 07-02-2009 10:11 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
