Garage GFCI Circuit Wiring Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 06:02 PM   #16
Originally Posted by jbfan View Post
I can't tell from the pics, but mine has a starting cap.
It sounds like it may be bad.
Hmm that very well could be..I bet you're right. Mine is a capacitor started motor. Never thought of that..thanks! I'll have to do some research on that. Have you ever had to replace a capacitor? I wouldn't think it would be too hard..just find the right replacement and wire it in?
woodworkerjeff is offline   Reply With Quote
Old 03-21-2011, 06:13 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Just take the cover off, find the number and find a repalcement.
2 wires and you are done.
jbfan is online now   Reply With Quote
Old 03-21-2011, 07:34 PM   #18
Looks like a simple fix. Just took the capacitor off and it is obviously blown..looks like it imploded on itself. I'm going to order a new one tonight. I take it a capacitor serves the same function that carbon brushes do on other power tools? Thanks again everyone..looks like this one is close to being solved
Old 03-21-2011, 11:30 PM   #19
" Euro " electrician
frenchelectrican's Avatar
Not excataly on this useage and the capaitor purpose to shift the voltage a bit for starting winding and some case you may have second capaitor for running winding which it will help to reduce the running current.
But the starting capaitor is the most common cuprit and next most common curpit is starting switch aka centifuge switch it will be on the motor rotor which it will have some type of flywheel weights there to move at X numbers of T/min { RPM } (note: this only used on single phase motours the triphase do not have them at all and very few single phase motours do not have them as well )
The carbon brush is complety diffrent function that is only on DC or AC-DC rated universal motour and they are wired in series with main winding so if you loose the brushes for some reason the motour will not run without it.
Hope that clear up that details.
Merci.
Marc
Old 03-22-2011, 10:44 AM   #20
Thanks again, Marc. That makes sense why a bad capacitor would cause the breaker to trip. Got a new capacitor ordered..can't wait to see how it runs once that is replaced!
Old 03-24-2011, 11:43 AM   #21
Thanks!!!
Got in the new capacitor and the drill press works great! Thanks for helpin me out on this one guys! Can't tell you how glad I am to have only spent $10 for a new circuit breaker and $10 for a new starting capacitor..i love happy endings like this
Old 03-24-2011, 12:12 PM   #22
jbfan's Avatar
Rewards Points: 478
Glad everything worked out for you!
Old 03-24-2011, 11:29 PM   #23
I am glad that you got it working good now you can use the drill press anytime.
Merci.
Marc
Old 04-06-2011, 12:34 PM   #24
thomask's Avatar
Hey JEFF,
That starting capacitor is the culprit many more times than not.
Glad you are up and running now.
THIS IS A GREAT GROUP ON HERE.
thomask is offline   Reply With Quote
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
Electrical problem in garage ginaca Electrical 10 04-19-2009 06:51 PM
Wiring Issue: Problem solving skkrman7482 Electrical 3 04-04-2009 06:32 AM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 03:27 PM
