Garage Electrical Idea - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 05:34 PM   #1
Let me know if this is a good idea or not.
I want to be able to add a couple of outlets to the garage but i don't want to tear into the drywall. My idea was to add a surface mount subpanel and run conduit to the outlet locations. Does this violate the electrical code?
cooper4x4 is offline   Reply With Quote
Old 01-13-2010, 05:58 PM   #2
Electrical Contractor
kbsparky's Avatar
What kind of (sub-)panel is out there now?
Surface mounting conduit and outlets is an acceptable wiring method.
-KB
Old 01-13-2010, 07:21 PM   #3
Household Handyman
Rewards Points: 1,408
We wired my cousins 30' x 50' workshop in this manner. We used a surface mount 200 amp breaker panel with main, ran conduit to all duplex outlet boxes, to all 22ov boxes, all light switches, all proposed light fixtures, and dropped two 220v boxes and one 110v box from the ceiling, all surface mount. After all the conduit was run, and his plywood ceiling was installed, he spray painted all the walls, the ceiling, and all the surface mounted electrical apparatus white. We checked, it was within code. Now everything sort of blends in. Not too bad. Thanks, David
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 10:24 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
