Garage Door Sensor Project - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 05:14 PM   #1
Garage door sensor project
Im working on a project to where i am want a light to come on when a line is crossed, and go off when the beam is restored. I was thinking this could be done with garaged door sensors, but not sure how or what i would need to make it work. I do not have a garage door opener that i am doing this to, It would be a scratch build. Anybody have an ideas. Thanks
deuce01 is offline   Reply With Quote
Old 06-29-2012, 06:20 PM   #2
MarginallyQualified
Rewards Points: 2,464
Omron
google it then find what you need at Grainger (or maybe amazon)
Old 06-30-2012, 09:20 AM   #3
Thanks. I saw those. I was hopping there was a cheaper solution. I need to have two sensors in my project and dont what to buy $300 worth of sensors.
Old 06-30-2012, 09:51 AM   #4
MarginallyQualified
You saw what?
Omron makes a gazillion different devices but so do others.
None of them should cost very much.
Old 06-30-2012, 05:57 PM   #5
Ok, ill look again. The sensors i saw were anywhere from $120 to $150 each. I am needing something to shoot a beam across 6' to 8'.
Old 06-30-2012, 06:03 PM   #6
This is what is saw when i was looking.
http://www.grainger.com/Grainger/pho...518&sst=subset
Old 07-01-2012, 10:08 AM   #7
Skyline makes a sensor for this specifically. For entering driveways so the lights come on when you pull up.
Darren R is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
