-   -   Garage door sensor project (http://www.diychatroom.com/f18/garage-door-sensor-project-148630/)
deuce01 06-29-2012 05:14 PM
Im working on a project to where i am want a light to come on when a line is crossed, and go off when the beam is restored. I was thinking this could be done with garaged door sensors, but not sure how or what i would need to make it work. I do not have a garage door opener that i am doing this to, It would be a scratch build. Anybody have an ideas. Thanks
TarheelTerp 06-29-2012 06:20 PM
Omron
google it then find what you need at Grainger (or maybe amazon)
deuce01 06-30-2012 09:20 AM
Thanks. I saw those. I was hopping there was a cheaper solution. I need to have two sensors in my project and dont what to buy $300 worth of sensors.
TarheelTerp 06-30-2012 09:51 AM
You saw what?
Omron makes a gazillion different devices but so do others.
None of them should cost very much.
deuce01 06-30-2012 05:57 PM
Ok, ill look again. The sensors i saw were anywhere from $120 to $150 each. I am needing something to shoot a beam across 6' to 8'.
deuce01 06-30-2012 06:03 PM
This is what is saw when i was looking.
http://www.grainger.com/Grainger/pho...518&sst=subset
Darren R 07-01-2012 10:08 AM
Skyline makes a sensor for this specifically. For entering driveways so the lights come on when you pull up.
