Garage Door Safety Sensor Wire Requirement - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 03:04 PM   #1
Question
Garage door safety sensor wire requirement
My garage door opener installation manual (139.53413) stated that garage door safety sensors were optional at the time I installed my garage door opener (about 20 years ago). I now want to install safety sensors.
I have purchased sensors and found a source that states I need a 2 conductor 22 awg solid core wire to connect the sensors to the motor.
Do I have the correct information as above? I have found a source for 2 conductor 22 awg stranded wire. Will the stranded wire work OK? The voltage is probably less than 24 volts.
Should the wire be shielded?
Thank you for your comments.
Cenzo22 is offline   Reply With Quote
Old 07-08-2014, 03:31 PM   #2
Rewards Points: 6,652
Just go to your local Big box store and they have rolls of the wire in the aisle that electrical wire is in. Also may have it in the area that the garage door openers are at.
Just standard Zip cord is used. Nothing exotic.
The Following User Says Thank You to gregzoll For This Useful Post:
Cenzo22 (07-08-2014)
Old 07-08-2014, 07:01 PM   #3
Remodeler
Rewards Points: 320
Just about any type will do, but I would stick to solid wire, it is much easier to work with in such a light gauge wire. The wire commonly used for doorbell wire works fine. Telephone wire or thermostat wire will work fine too. No shielding is needed.
Hopefully you purchased the correct sensor eyes for your model and brand of opener, they are different and have changed specs even within the same brand over the years.
iamrfixit is offline   Reply With Quote
Old 07-08-2014, 07:47 PM   #4
Rewards Points: 3,338
I bought a large roll of cat5 cable which I use for all that little stuff. Comes in handy. Did my garage low voltage wiring with it... my alarm... even did my low voltage patio lights with it. Versatile and universal!
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 07-08-2014, 08:13 PM   #5
Thank you for your reply. I will go to either Lowes or Home Depot to get solid core wire. I have found the 22 awg 2 conductor is usually called Bell Wire.
I had a difficult time finding out which sensors I needed but the Sears online help line confirmed the type sensors I needed.
I need further help with connecting the sensors to the motor but will write another request for assistance.
Old 07-08-2014, 09:06 PM   #6
The garage door manufacturer will state what sensors that need to be used with their opener. If unsure. Email or call them.
Old 07-09-2014, 02:45 PM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Cenzo22
Thank you for your reply. I will go to either Lowes or Home Depot to get solid core wire. I have found the 22 awg 2 conductor is usually called Bell Wire. I had a difficult time finding out which sensors I needed but the Sears online help line confirmed the type sensors I needed. I need further help with connecting the sensors to the motor but will write another request for assistance.
Use bell wire or T-stat wire. It also needs to have a CL2 rating.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Cenzo22 (07-09-2014)
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 01:50 PM
