Garage Door Openers - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 09:45 AM   #1
Rewards Points: 150
garage door openers
Should I put two garage door openers on a dedicated circuit? And if I put them on a circuit protected by a gfci upstream, would they cause much nuisance tripping? Thanks
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 07-28-2010, 09:48 AM   #2
Licensed electrician
Rewards Points: 1,876
If I had space for a dedicated breaker I would do it.
GFI protection is required under the 2008 NEC. Tripping should not be an issue. I would however put the GFI where I could reset it without needing a ladder if it were to trip.
Old 07-28-2010, 02:30 PM   #3
57_Hemi's Avatar
Regarding it "tripping"....dont think it would be a problem. However, I would prefer them on seperate cct's. Simply for the fact that if the cct trips one day (maybe from a problem NOT located in the garage) at least u still have the 2nd door powered up and working normally.
my 2 cents
57_Hemi is offline   Reply With Quote
Old 07-28-2010, 05:01 PM   #4
Yup, I'm going to install my doors on 2 seperate circuits
That way if one kicks out I can still open the other door
I'll locate GFCI's where I can reach them, then the load side will feed outlets on the ceiling
Old 07-29-2010, 12:42 PM   #5
RST
DIY Homeowner
Rewards Points: 150
I read elsewhere that an NEC table claims a 1/2 hp motor draws 9.8 A at 120V. A single 20A circuit could handle two openers but 3/4 hp motors are becoming more popular. (I just installed one on my other garage door and like it much better!) Upon further reflection, I should probably split my openers onto 2 circuits...
RST
RST is offline   Reply With Quote
Old 07-29-2010, 03:15 PM   #6
I'd think motors have a generic exemption to GFCI protection because the normal capacitance from the motor windings to the motor shell [ground lead] causes several mA to flow.
Old 07-29-2010, 03:30 PM   #7
Electrician
Proby's Avatar
So what are you trying to say? That we shouldn't follow the NEC because you think motors are exempt?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 07-29-2010, 03:35 PM   #8
There is no exception under the 2008 NEC for the GFI protection.
Also UL has limits on acceptable motor leakage that is about 1/10 of the trip level of a GFI.
Old 07-29-2010, 03:38 PM   #9
Originally Posted by Proby View Post
So what are you trying to say? That would shouldn't follow the NEC because you think motors are exempt?
There was a guy, possibly on this forum, who had his washing machine tripping a GFCI. After a very lengthy thread the OP said that the manuf. confirmed that his machine was exempt.
Old 07-29-2010, 04:31 PM   #10
There was a guy, possibly on this forum, who had his washing machine tripping a GFCI. After a very lengthy thread the manuf. confirmed that his machine was exempt.
I find it hard to believe that the washer was exempt from the UL standard or that someone paid extra to get their machine listed under a different standard. Show me the proof.
Old 07-29-2010, 05:00 PM   #11
Electrician
Proby's Avatar
The manufacturer is in no way, shape, or form an authority to make that determination.
It's like a Black and Decker saying that I could plug one of their toasters into a 50amp circuit wired with 18 gauge zip cord.
The exemption for garage door openers is no longer in the NEC (as far as 2008), what a manufacturer said over the phone does not change that.
Old 07-29-2010, 05:12 PM   #12
Did the NEC give a rationale for removing this exemption?
In general, are the reasons for NEC decisions available anywhere on the Net?
Just curious. Very curious.
Old 07-29-2010, 05:15 PM   #13
Electrician
Proby's Avatar
Join Mike Holt's forums, they got all the answers you'll need
Old 07-29-2010, 05:16 PM   #14
Seems like the motor technology has changed
http://www.google.com/search?hl=en&s...=&oq=&gs_rfai=
and not the GFCI technology.
The code violation questions/articles in the back of EC & M are the closest I'd like to get to Mr. Holt and his gang. . .
And, for some Holt gossip, it seems that a former member of their forum who was subsequently banned is probably the same person who sued his high school for the right to pass out Creationist literature. And won.
Old 07-29-2010, 05:59 PM   #15
I=E/R
a7ecorsair's Avatar
When I wired my garage four summers ago, I put all the outlets on GFCIs (of course). I have yet to have a ground fault. I've run a table saw with a 3/4H.P. 60+ year old motor, a band saw, skil saws, a drill press, air compressors, wire feeds, and numerous other portable 120V tools. I can't see where ground faults are a problem with motors.
a7ecorsair is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
