Garage Door Opener Power - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 12:42 PM   #1
Rewards Points: 150
garage door opener power
Hello,
I'm planning to redo the wiring in my 1950's two car garage. As it stands both garage door openers are on a 20 Amp circuit by themselves. Is there a good reason for this or could I add some general purpose lighting and such on this branch? Thank you
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 11-23-2008, 01:10 PM   #2
Eibwen
Most garage door openers are only 1/2 HP motors so they would only draw about 3 amps each.
Sammy is offline   Reply With Quote
Old 11-23-2008, 03:19 PM   #3
Rewards Points: 6,652
One reason would be that if you have other outlets connected to that circuit, you do not have to worry about loosing lighting if you tripped the breaker. BTW, are the openers connected to a GFCI breaker? That along with having another form of egress if the doors cannot be opened when power fails?
Old 11-23-2008, 04:32 PM   #4
Rewards Points: 150
yes, there is a back door in the garage. NOTHING in this old garage is ground fault protected which is one reason it's going to be redone. By the way, I plan on having some lights on another circuit.
Warren Zevon
Old 11-23-2008, 08:30 PM   #5
If the wiring is up to par, and has a ground wire, only thing that would have to be redone is check the person that put it in work to make sure up to par so that you can place a GFCI breaker at the line, then for the lights, add a 14/2 leg off of a 15 amp Breaker.
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
Garage lost power jkrodger Electrical 4 11-04-2007 09:50 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
