Garage Door Opener Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 11:09 AM   #1
Garage door opener lights
We had a big storm earlier in the week with a strong power surge that took out the telephone pole on our cul de sac.
Apart from the phones/internet the only problem we have had is the lights on our garage door opener will not work, we have 3/4 Chamberlain Whisper drive that is less than a year old.
I have tried a variety of types of bulbs, but no cigar. The motor works fine and all of the remote controls work fine as do the safety sensors.
I've done some reading and it seems that lightening/power surges love the "logic board", does that seem consistent with what I have mentioned above? If so is there a cheaper way to fix this other than purchase a whole new system?
As a side note, our opener is plugged into the side light socket using a 3 prong to 2 prong converter, is there a safer way to do this?
My light socket looks like this -
wilto is offline   Reply With Quote
Old 06-03-2012, 03:04 PM   #2
Rewards Points: 776
When you forgo the ground plug you effectively disable some if the electronics for the purpose of lightening protection. So it is not a good idea to eliminate the ground.
Having said this it is curious everything seems to work but the lights. Further the lights are probably engaged by a relay on the logic board so not as fussy as the rest if the circuits to surges.
Are you sure you don't just have bent contact in the bulb socket? I run That down before declaring the logic board dead.....
curiousB is offline   Reply With Quote
Old 06-03-2012, 09:45 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
It is not uncommon for lightning strikes to take out garage door openers. Happened to one of mine years ago. Lightning struck the neighbors house and fried my opener. The circuit boards can be replaced. Mine was plugged into a grounded outlet, so that doesn't necessarily protect them. A plug in surge protector would do a better job. You should install a grounded outlet for the opener before you put a surge protector in.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Fluorescent lights in the garage do not all turn on noone Electrical 8 07-01-2011 10:51 PM
How to wire a detached Garage? (w/ Conduit?) FLintonRice Electrical 7 06-27-2011 02:08 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Garage Lights Git Electrical 9 03-20-2008 09:35 PM
